Good place to run wires through firewall? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Good place to run wires through firewall?
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineSavvy Aluminum BumpersThe RuffStuff "I can't go to EJS" Sale!
Unread 12-07-2013, 06:44 AM   #1
Pierre_r
Pierre_r's Avatar
1989 XJ Cherokee
I know there was a thread that was about this but i cant find it now.
I have a hdh switchpanel that i am going to mount in my ZJ to controll lights and other things.
Are there are already holes in the firewall that i can use and run wires from the relays and to the controll unit that comes with the kit?
Or i have to drill my own ?
Since it has 8 switches i was thinking that i could prepare the others for future use by already run the wires to it so i would need to run in 8 wires from the enginebay.
Then i must have room for the 10awg wire for the power to the controll unit and a small 18awg for the ground, so in total 10 wires from the enginebay to the inside.
The wiresize i was thinking of using for the relay,s is 2.5mm2 (14awg)
Pierre_r is offline   Reply With Quote
Unread 12-07-2013, 11:11 AM   #2
kildog65
So on the passenger side where your antenna is you can run a wire from under the hood through a he where your antenna is on the front passenger side and there is a grommet there with the antenna wit running through and then you can easily run wires under your dash to the driver side
kildog65 is offline   Reply With Quote
Unread 12-07-2013, 11:56 AM   #3
JasonStebbins
Obv
JasonStebbins's Avatar
I have two holes that I use for all my auxiliary stuff. Drilled them behind the passenger carpet right in the middle, then along the left side coming through where the VIC was.
Common ZJ problems and how to fix them by JasonStebbins
http://www.jeepforum.com/forum/f13/c...x-them-1432264
12 things to do when your ZJ stalls by ZeeJay1997
http://www.jeepforum.com/forum/f13/1...talls-1407423/
JasonStebbins is online now   Reply With Quote
Unread 12-07-2013, 12:27 PM   #4
durango-bob
There are a few large rubber grommets that already have stuff going through the firewall. I've put holes in the grommet and run wires through those.
durango-bob is offline   Reply With Quote
Unread 12-07-2013, 12:57 PM   #5
JasonStebbins
Obv
Are these on the driver's side? All my wires come through the passenger because it's a clear path over there.
Unread 12-07-2013, 02:40 PM   #6
WhiteOut
WhiteOut's Avatar
There is an existing hole in the driver's side firewall that has a plate bolted over it. Or alternatively, just run them through the same hole as the hood release cable.
WhiteOut is offline   Reply With Quote
Unread 12-07-2013, 03:03 PM   #7
Pierre_r
Pierre_r's Avatar
1989 XJ Cherokee
Ok i have to go out and check tomorrow when it is light outside and see if i can find any of those spots that you are talking about.
Unread 12-07-2013, 04:46 PM   #8
Darkrocker
Pretty much exactly what I did with all the wiring for my lights. Mounted my switches on the drivers side above where my right knee would rest, ran the wires behind the VIC/Climate control area and under the carpet to the passengers side. The power for my roof lights ran from the same area, then up behind the door jab (where the factory overhead harness is), up the a-pillar and through a small hole in the roof which comes out under the roof rack mounting rail.
Darkrocker is online now   Reply With Quote
Unread 12-08-2013, 11:09 AM   #9
bjorn17
Interesting. Care to explain a bit further? Where can it be seen directly?
BTW 5.2l engine.
bjorn17 is offline   Reply With Quote
Unread 12-08-2013, 11:33 AM   #10
OverlandZJ
BTW 5.2l engine.
Between the master cyl and fender, where the clutch master would have been installed.
I'v used this area for my CB coax, and other wiring such a my Hella's. Several relays mounted there as well. Use appropriate sized grommets.
OverlandZJ is offline   Reply With Quote
Unread 12-08-2013, 11:59 AM   #11
bjorn17
Cheers, will check that out. Just installed lights in front and used the hood cable grommet but that was a lot of pain. Will see that option next.
B.
Unread 12-08-2013, 12:43 PM   #12
Pierre_r
Pierre_r's Avatar
1989 XJ Cherokee
i found the plate on my ZJ and then i found it in the fsm
Here is it:
Dont know how to make the pic bigger but the plate that covers the hole is #9
Unread 12-08-2013, 01:08 PM   #13
WhiteOut
WhiteOut's Avatar
Yep, thats the one I removed.
Unread 12-08-2013, 08:43 PM   #14
Mickey_D
Just one thing I'd like to add:
You said the power wire is 10ga but the ground is only 18ga. All ground wires should ALWAYS be larger (at bare minimum the same size) as the power wires. ALWAYS.
1997 ZJ 5.2 Orvis, Baby!
1953 Willys M100 trailer Tagalong
________________
[_][][][][][][][][_]
Mickey_D is offline   Reply With Quote
Unread 12-08-2013, 09:01 PM   #15
RICEKILA
I carefully just use an ice pick through the A/C hose gromett -- usually enough space for a few wires and makes a good seal -- on the YJ the wires come out under the battery --
P/S -- for the light bar I just finnished -- two light wires / two ground wires / and an extra just because I was under there -- all 10g. through their own holes --
I was once a tree house.
I lived in a cake.
But I never saw the way - the orange slayed the rake --
RICEKILA is offline   Reply With Quote
