Good Hole Thru Firewall - JeepForum.com
post #1 of 9 Old 02-13-2009, 10:41 AM Thread Starter
gbuddyjoe
Hey all,
I have a 98 Grand Cherokee and I need a hole thru the firewall to run a 10gauge power wire for an amplifier... could anyone direct me to where in the Deuce a good hole could be cuz i can't seem to find one!
Help please.
Thanks
gbuddyjoe is offline
post #2 of 9 Old 02-13-2009, 11:55 AM
ZJ_Dave
There isn't really an existing hole to put it through, but there is plenty of room to drill a hole. I put 4 gauge wire through mine. I'll get a picture of the spot when I get home.
Is it summer yet?
'98 ZJ! 4.0L Laredo, with some upgraded stereo stuff.
Originally Posted by greasefingers
Great pictures! Now I know what she looks like naked.
ZJ_Dave is offline
post #3 of 9 Old 02-13-2009, 12:00 PM
MeWJWifeZJ
I drilled a hole with a standard drill between the intake and the power booster. THere is a nice flat open spot there
Praise to a Child is like Sunlight to Flowers
Traded away the WJ to get a commuter
We finally got another Jeep after 5 years without. Too bad it's ALL stock.
MeWJWifeZJ is offline
post #4 of 9 Old 02-13-2009, 12:18 PM
WhiteOut
WhiteOut's Avatar
There is an existing hole on the drivers side just by the booster, goes right through and comes out under the steering wheel. I have my CB cable and light wires through it
WhiteOut is offline
post #5 of 9 Old 02-13-2009, 01:00 PM
Linus
x2 i have a WJ but i searched all over the passenger side floor and kick panel, nor really a good spot to do it. i gave up and ran it thought the existing hole behind the gas pedal, and ran it over top of the engine bay to the battery.
i fit a 4awg power wire through it just fine
04 WJ - 4.0L and Selec-Trac
BDS 2", 3/4" spacers, Bilstein 5100, and 31" General Grabber AT2's
Linus is offline
post #6 of 9 Old 02-13-2009, 01:07 PM
RubiExpressTJ
1987 YJ Wrangler
There was a hole with a rubber plug in it if i remember correctly behind the valve cover and to the left a little bit on my 96.
- Luke
RubiExpressTJ is offline
post #7 of 9 Old 02-13-2009, 01:21 PM
footinmouth47
footinmouth47's Avatar
this is where I had mine until I got tired of looking at all those wires running across. So I drilled a hole under the ac condenser in the passenger floorboard and ran the wire through the unibody rail up to the front and it comes right out under the bat. very clean. Oh and its a 98 as well so it would be the same as yours.
this is the thread where emtim has good pics.
http://www.jeepforum.com/forum/f13/all-wiring-electronic-gurus-out-there-495329/
Greg
98 zj (The Vixen) 5.2 V8, 4 in f>r, 31's,
Built not Bought member #247
SOLD:( new DD- 04 polaris sportsman
footinmouth47 is offline
post #8 of 9 Old 02-13-2009, 01:45 PM
AgitatedPancake
you people need to start checking out the rubber hoses for all the electronics in the door. I have my WJ ran through the passenger side one. I took a razor and cut a small slit for the wire to exit towards the engine bay. I could silicone it to reseal but I dont think its necessary, i've had it like this for years. I have a 0 gauge and a 4 gauge run through it together right now. The wire will end up between the inner fender (structure) and outer fender (sheetmetal), you can route it through there into the engine compartment AND its the shortest possible route.
To contact me, email
01 WJ 5 Speed Claytons LA's, 36" Iroks, 35 spline 9" rear, Custom Ruffstuff 60-9" front axle.
Build Thread:
AgitatedPancake is offline
post #9 of 9 Old 02-13-2009, 04:03 PM
ZJ_Dave
Right next to an existing grommet in the firewall. It's straight back from the battery.
Is it summer yet?
ZJ_Dave is offline
no hole in WJ firewall? g-off70 ZJ Grand Cherokee Forum 16 12-01-2009 05:18 PM
Hole in 96 ZJ Firewall 1996LaredoZJ ZJ Grand Cherokee Forum 0 04-08-2009 10:58 AM
96 zj is there a hole in battery side of firewall??? cirame1 ZJ Grand Cherokee Forum 2 11-26-2008 08:32 AM
Hole in Firewall to run wires? bgky ZJ Grand Cherokee Forum 2 12-13-2005 08:36 PM
