Is this going to be a decent viscous coupler? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Is this going to be a decent viscous coupler?
Metalcloak: Celebrate Freedom with Free ShippingFS: Wrangler RGB Multicolor Fog Light LEDs: Awesome EffectIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 07-01-2015, 09:38 AM   #1
Jd_joe
Found this on Ebay. I'd like to retain the AWD aspect of the 5.9 limited I just picked up. Viscous coupler is on the way out. Is this cheap rebuild gonna be a decent replacement?
http://m.ebay.com/itm/221792607753?_...25.m3641.l6368
Jd_joe is offline   Reply With Quote Quick reply to this message
Unread 07-01-2015, 09:55 AM   #2
XJ93
I thought the VC was different between gen one 249 and gen two 249?
XJ93 is offline   Reply With Quote Quick reply to this message
Unread 07-01-2015, 09:59 AM   #3
XJ93
I will say though I am not too keen on that one and one warranty. Just because they remanufactured the coupler doesn't mean it's good. I have had a few bad reman parts come into my store.
Unread 07-01-2015, 10:28 AM   #4
Cbob4
Does anyone know what the warranty is on the Crown VC? No, that's not a Crown Vic...
Cbob4 is offline   Reply With Quote Quick reply to this message
Unread 07-01-2015, 10:49 AM   #5
PolkaPower
There are different part numbers fro the VC throughout the years. I'm not sure what the difference is from 96+ but I would not use a 93-95 VC on a later model. As far as that goes, you used the words "cheap replacement" for the VC hahahaha
PolkaPower is online now   Reply With Quote Quick reply to this message
Unread 07-01-2015, 10:54 AM   #6
TreeFeather
let me know if it does work.
TreeFeather is offline   Reply With Quote Quick reply to this message
Unread 07-01-2015, 10:59 AM   #7
PolkaPower
You won't know unless it's bad right away. It might work for a week, 6 months, or a year.
But do let us know if it fails right away.
Unread 07-01-2015, 11:04 AM   #8
TreeFeather
Ill take it if it lasts a year. lol Im sick of not having a front ds in my 5.9. This will be my 2nd or 3rd one in that beast. If I do it........ my 95 has been steady on one I replaced way back.
Unread 07-01-2015, 11:16 AM   #9
LowBudgetZJ
Can't you just pull the vc and run the newer 249 that way?
IIRC, you'll have 2hi and 4low lock after reinstalling the front drive shaft.
Although, I'm down in fl so no need for the awd, I'd rather have 2hi and 4low.
98 ZJ 4.0 42RE NP242
LowBudgetZJ is offline   Reply With Quote Quick reply to this message
Unread 07-01-2015, 11:23 AM   #10
kg6mov
Hears the voices
kg6mov's Avatar
The VC part number changed in 97, not with the first gen second gen switch. The difference in first and second gen 249's is mechanical in the case not the VC.
On a second gen 249 you can remove the VC and you will have 2hi and 4lo (locked).
If quality fluid was used then a reman vc should be fine. Run with matched tires a VC should get 200k.
1996 ZJ Green Laredo V8, 2.5" OME and Bilsteins, 33's, Holes drilled in the roof.
1998 ZJ Platinum Limited 5.9, Backyard parts fodder
kg6mov is offline   Reply With Quote Quick reply to this message
Unread 07-01-2015, 11:28 AM   #11
Jd_joe
His Ebay description claims it will work on all 249j cases. He goes in to detail on why that is. Anyone read that and agree or disagree? Certainly seems cheap enough.
Unread 07-01-2015, 11:54 AM   #12
kg6mov
Hears the voices
kg6mov's Avatar
That makes sense, and is why I said "part number" changed. I know it wasn't a mechanical difference in the coupler itself, good to see that confirmed. Sounds like he knows what he's talking about, I'd go for it.
Unread 07-04-2015, 06:56 AM   #13
Adwex
Why does this one look so different?
http://www.ebay.com/itm/Jeep-249-Tra...5cdbad&vxp=mtr
I'm gonna need one too, I'm probably gonna have the whole TC rebuilt.
Adwex is offline   Reply With Quote Quick reply to this message
Unread 07-04-2015, 10:42 AM   #14
PolkaPower
Thats the other side
Unread Yesterday, 11:08 AM   #15
Adwex
No need to laugh, I assumed the pics in the ebay listing showed both sides.
http://www.ebay.com/itm/221792607753
