Going from 16" to 15" wheels possible ? - JeepForum.com
post #1 of 13 Old 10-27-2016, 01:19 PM Thread Starter
mikemann0
I have a new to me 96 Grand Cherokee limited v8 awd with stock 16's dana 44 disc rear , The cost diff between 15's and 16's is a bit for new wheels and tires so can I go down or will I have clearance issues , Plus used 15's are way more common used , Thanks.
96' ZJ , 5.2 Magnum , AWD , Dana 30 , Dana 44 , Flo master , Test pipe
mikemann0 is offline
post #2 of 13 Old 10-27-2016, 01:53 PM
kg6mov
Hears the voices
kg6mov's Avatar
ZJ came with both 15 and 16" wheels, either will fit.
kg6mov is offline
post #3 of 13 Old 10-27-2016, 02:07 PM
GOLDWING
^^^ What KG said. Stock lug pattern is 5 on 4.5". Backspace should be 5" from inside rim to mounting surface.
GW
2 '98 4.0 ZJs
Hers is stock, mine, OME shocks, BB, Aussie, 2x6 sliders, 31s, etc.
GOLDWING is offline
post #4 of 13 Old 10-27-2016, 02:19 PM Thread Starter
mikemann0
Awesome guys thank you , Wasn't sure about the rear disc brake , Have had a few zj's but all were drum rear.
post #5 of 13 Old 10-27-2016, 03:29 PM
kg6mov
Hears the voices
kg6mov's Avatar
Nope, rear discs are so tiny you won't have any issues. I've got four corner disc and 15's from the factory.
kg6mov is offline
post #6 of 13 Old 10-27-2016, 03:45 PM Thread Starter
mikemann0
Good deal ,Thanks kg6mov.
post #7 of 13 Old 10-28-2016, 01:35 AM
JoeUbo
Is that the same for Niners
Sent from my iPhone using Tapatalk
JoeUbo is offline
post #8 of 13 Old 10-28-2016, 06:36 AM
GOLDWING
Yep
2 '98 4.0 ZJs
GOLDWING is offline
post #9 of 13 Old 10-28-2016, 12:32 PM
kg6mov
Hears the voices
kg6mov's Avatar
Yep, nothing special about the niner axles/brakes.
Except that stupid 1330 u-joint.
kg6mov is offline
post #10 of 13 Old 10-28-2016, 01:59 PM
Timo_90xj
Timo_90xj's Avatar
Well those 1330 rear DS u-joints are about 25% stronger than the tiny 1310s, so nothing stupid there
..but, they should've had 1350s from the factory
***Under construction***
Timo_90xj is offline
post #11 of 13 Old 10-28-2016, 02:12 PM
kg6mov
Hears the voices
kg6mov's Avatar
Yeah, but a 1310 is still spec'd way above what a stock niner puts out. All the V8's should have gotten something better than the 1310 all around IMO, but doing it just for the 5.9 and only in the back is more annoying than anything else.
Says the guy with a niner rear shaft and axle . . .
kg6mov is offline
post #12 of 13 Old 10-28-2016, 02:15 PM
Timo_90xj
Timo_90xj's Avatar
Going very much off-topic, but some trivia 1330 not mentioned, but it's torque rating is pretty much in between 1310 and 1350 ratings.
post #13 of 13 Old 10-28-2016, 04:09 PM
Buick350X
Totally feel ya there, lucky for me at some point someone ditched the 16in alloy rims and put 15 steel rims on mine.
My wallet is much happier. Running 235/75R-15 Goodyear Wrangler , black wall out... I have rear disc brakes.
1995 Jeep Grand Cherokee Orvis 4.0L Up-Country + BB - facebook groups JeepOrvis.Club JeepZJ.Club
Buick350X is offline
