A girl with power issues ... - JeepForum.com
post #1 of 11 Old 06-08-2006, 07:48 PM Thread Starter
PlatoHedron
I don't normally power-trip, but I thought this forum would be a good place to start
I have a Ďmaybeí sunroof. Maybe it opens, maybe it doesnít - most times not. I have a dreaded fear that one day it will stop working in the open position, then Iíll have do to some heavy negotiation with someone who has covered parking. The motor on it is relatively quiet so I cannot tell if itís the switch or the motor. Is there any way to check?
Another power issue I have is with the locks. The keyless entry/alarm will only unlock the driverís side door intermittently. The double-press to unlock the rest of the vehicle is fine. Itís just a problem with the driverís side door. Sometimes it takes me 5 or 6 tries before itíll unlock. I swear that I can hear the little motor trying to unlock it, but in the end it doesnít. How many different things do I need to check out to figure out what the deal is with the locks? Also, there are times when I use the inside button to lock the doors, when using the keyless fob wonít work, and itíll lock everything except the front passenger door.
Any thoughts?
Mahalo in advance to all who help me!
Sky
[it's a 3-banana day!]
- Sky
Live Aloha, Be Aloha, Embody Aloha ... And if you can't - fake it till you make it.
no money = no mods (however, willing to accept donations - inquire within)
PlatoHedron is offline
post #2 of 11 Old 06-08-2006, 08:10 PM
GreenDean
GreenDean's Avatar
The locks.
I would pull the door panel off and hose all the linkages and locking mechanism down with some lube. PB Blaster or WD40 to loosen them up.
If that doesn't work... the lock actuator motors are probably shot. But start with the lube... it's the easiest and first thing to try.
The sunroof.
Could be the switch or the motor.
If you pull the switch out you can use a jumper wire to by pass the switch and see if it opens and closes the roof everytime... if it does... then you know you have a bad switch.... if it doesnt... you know you have a bad motor. But it's most likely the swtich... Jeep seems to be lacking in the switch design department
GreenDean is offline
post #3 of 11 Old 06-08-2006, 08:20 PM Thread Starter
PlatoHedron
Mahalo Dean!
- Sky
post #4 of 11 Old 06-08-2006, 08:22 PM
GreenDean
GreenDean's Avatar
Mahalohoholooloohaha! What ever the heck that means.
post #5 of 11 Old 06-08-2006, 08:26 PM Thread Starter
PlatoHedron
'olelo Hawai'i
mahalo = thank you.
- Sky
post #6 of 11 Old 06-08-2006, 08:29 PM
moparracing
what he said..........
2005 Dodge Ram SRT-10 RC, Yellow Fever #146 out of 500
srt-10 pics :
moparracing is offline
post #7 of 11 Old 06-08-2006, 08:31 PM
GreenDean
GreenDean's Avatar
No problem. Whats "Your Welcome" in Hiwanise?
post #8 of 11 Old 06-08-2006, 08:36 PM Thread Starter
PlatoHedron
hahaha. there really isn't a "you're welcome" in Hawaiian...
most of us simply use: a'ole pilikia = no problem. (ah-oh-lay pee-lee-key-ah)
you guys make me laugh
Sky
- Sky
post #9 of 11 Old 06-09-2006, 04:41 AM
mrese
mrese's Avatar
Ive had issues where the key FOB didnt work, had to pop it apart clean the battery contacts. The sunroof.........well cant help ya there.......
Mark
Amsoil Dealer
'99 WJ Limited 4.7 K&N Filter CB 3" IRO
302, 000 miles
mrese is offline
post #10 of 11 Old 06-09-2006, 11:37 AM
UFO
UFO's Avatar
that ****ing sunroof.
Be careful that if it does get stuck, that its not even the slightest bit in the open position (so that the wind bar is down, and the window is still cracked.) I was driving across an interstate bridge towards an airport when both the glass and the plastic interior cover popped off from the wind and pressure. It scared the **** out of everyone in the car and our ears all popped. I'm just glad it didn't hit anyone behind us. Needless to say, the motor still works great but most of the track that holds the glass is gone. I got a sunroof specialist to silicone in a piece of glass from a 97 grand.
Sunroof -> Moonroof conversion complete. $150 including installation.
And hey, where that plastic cover was I can store my cd's and other crap!
Rig: 1995 JGC 5.2L V8 Limited 129K Installed: 4.25" (Rusty's 3" coils and 1.75" spacers, removed stock spacer) with 32x11.5R15 Pirelli "Scorpion A/T's" on Cragar "Soft 8's" || Rusty's Adj. Front UCAs and LCAs, Adj. Front Trackbar, Shocks and Steering Stab. || Kevin's Adj. Rear Trackbar || R.E.'s Extended Swaybar Links w/ conversion kit
UFO is offline
post #11 of 11 Old 06-09-2006, 01:41 PM Thread Starter
PlatoHedron
Excellent lemons to lemonade!
When it does work, I have a hard time getting it to stop in the proper seated position. Sometimes it wants to either pop the back of the window (when I'm closing it from it being slid back), or it wants to open (when I'm closing it from it being popped open on the back).
I'm sure I'm just playing with fire when I open it. Let's hope that I can find someone who can test the switch and motor before it decides to stop working all together.
Although there can never be too much CD strorage
Mahalo to all!
Sky
- Sky
Grand Cherokee power lock issues Char250r ZJ Grand Cherokee Forum 9 03-19-2011 03:48 PM
power issues!! VERY ANNOYING! Jeep2k55 ZJ Grand Cherokee Forum 2 01-04-2010 04:00 PM
wondows and power lock issues. gonejeepin04220 ZJ Grand Cherokee Forum 3 09-14-2009 10:52 AM
No Ignition Power, Then Starts, but has Issues charlierh2 ZJ Grand Cherokee Forum 2 12-07-2008 05:44 PM
Power Steering issues mdoug445 ZJ Grand Cherokee Forum 6 04-24-2007 12:38 PM
