Getting a tranny cooler. - Page 2 - JeepForum.com
post #16 of 20 Old 06-10-2013, 11:33 AM
PolkaPower
Originally Posted by RagTagSoldier View Post
Lol I might just do tht. But knowing I already have one I'm not in a hurry to get it done. I guess I can plan it out over the weekend. Is there already a power steering cooler under the hood or does it run through the rad?
Sent from my iPhone using JeepForum and has probably been edited.
There is not a power steering cooler of any kind. Look at the hoses. Just goes from pump to gear and back.
PolkaPower is offline
post #17 of 20 Old 06-10-2013, 11:37 AM Thread Starter
RagTagSoldier
So just splice the hoses into the aux cooler, and top off fluid. Easy enough. Is there any benefit of this. Sorry for not looking at the moment I just got off break lol.
RagTagSoldier is offline
post #18 of 20 Old 06-10-2013, 11:44 AM
PolkaPower
It keeps the fluid and pump cooler so they last longer. The power steering heats things up quite a bit.
post #19 of 20 Old 06-10-2013, 12:22 PM Thread Starter
RagTagSoldier
Hm I had no idea. Well that's a definite must do then.
post #20 of 20 Old 06-10-2013, 03:58 PM
LouC
2007 WK
Yep that means you got it, they removed it for 98 for some reason. They did make the rad a bit bigger and the internal cooler bigger. The B&M I put in is bigger than the OE one, which would make a good PS cooler. Just make sure you flush out the cooler well because the fluid Chryco puts in the PS system is not the same as trans fluid. I never had a problem with the PS even when towing or driving on the beach, but if you want to do it then go for it. Just make sure there are no leaks.
2007 WK Limited Hemi QDII
1998 ZJ Laredo 4.0 Selectrac
LouC is offline
