Getting ready to rip all of my hair out HELP PLEASE - JeepForum.com
post #1 of 6 Old 07-10-2011, 07:52 AM Thread Starter
Hemimonster425
2014 JK Wrangler
1998 JGC 4.0 if i let it sit for a day or two battery drains. I figured out that it is the number seven fuse which is the cluster fuse anyone else ever have a problem and figured a solution?
Hemimonster425 is offline
post #2 of 6 Old 07-10-2011, 09:07 AM
ZombieJeep93
Fuse 7 also powers the BCM (Body Control Module). The BCM controls most of the body related systems (headlights, auto headlights, vehicle theft, rke, interior lights, etc). This is the most likely cause of the problem. Its located on drivers side of instrument panel (dash) below the farthest left switch pod. You'll have to remove a panel or two below steering column to get to it. Unplug the connectors to it (3 of them, I think) and leave it unplugged for a couple of days and see if the battery still drains. The optional power amp is also powered by fuse 7. That should be under the rear seat, possibly rt side. But start with BCM, thats usually the one to cause problems.
93 Grand Wagoneer (de-wooded) 5.2 Mag, 2"BB, Magnaflo Cat, Gibson ex, K&N CAI, Mopar pcm, 32" BFG AT, Accel truck ignition
ZombieJeep93 is offline
post #3 of 6 Old 07-10-2011, 09:44 AM
JS97ZJ
Rear hatch ajar switch is toast. It's keeping the BCM from going to sleep after the courtesy time out shuts down.
It might also be one of the door actuators, but this problem seems to be on the rise for some strange reason. .
JS97ZJ is offline
post #4 of 6 Old 07-10-2011, 01:59 PM Thread Starter
Hemimonster425
2014 JK Wrangler
also none of the lights are staying on im going to unplug the bcm. I unpluged everything in the rear door i think that is where the problem is comming from any solutions
post #5 of 6 Old 07-10-2011, 02:20 PM
tato1111
Yea my drivers door just did this. i had to take the door switch off. The funny thing is that Everything still works the same.
White zj 6in. 33x12.5 1995
<--Mods in profile
tato1111 is offline
post #6 of 6 Old 07-10-2011, 02:20 PM
airwolf9090
I been having the power drain problem myself have you checked to see how many amps are being drained while its off? Mine is draining 3-5amps a min with it keyed off but if i open a door the amp drain goes to next to nothing a min and when i shut the door when the courtesy lights go out the 3-5amp draw is back..... So i just pulled the 7 fuse myself to see if it stops... I bet our two problems are the same thing so post back if you find out what it is....
1996 Jeep ZJ Orvis
airwolf9090 is offline
I have to gas ready..... DothanJeep ZJ Grand Cherokee Forum 29 06-10-2009 08:02 PM
Weird Coolant Leak Help!! Ripping my hair out!! xavier27 ZJ Grand Cherokee Forum 8 07-11-2007 02:21 PM
Getting ready to buy...need some help... 96grandjeep ZJ Grand Cherokee Forum 3 06-12-2006 07:51 PM
Im Gonna Pull My Hair Out! Lift Kits vipersrt1 ZJ Grand Cherokee Forum 5 05-25-2005 03:24 AM
Pulling Hair 4weeln ZJ Grand Cherokee Forum 1 03-02-2005 04:50 AM
