getting driver's door window out - JeepForum.com
post #1 of 4 Old 04-04-2009, 11:48 AM Thread Starter
alexsious
i need help on lowering the glass in the window. the haynes manual says to remove the trim panel and water shield and lower the glass. well that means no power to move the window down! which doesn't matter anyways because my motor is shot so i am trying to replace it, but i have to remove the regulator, which means lowering the glass to get it out. How do i move it manually?
alexsious is offline
post #2 of 4 Old 04-04-2009, 12:23 PM Thread Starter
alexsious
bump. please help. i cannot continue until i get the window down to remove the clips!
post #3 of 4 Old 04-04-2009, 01:11 PM
Mickey_D
Can you remove the motor itself? Once the motor and its gearbox is out of the loop, there should be nothing holding the regulator from moving.
If not, is there a way to jumper the motor to power and assist it in moving the window?
1997 ZJ 5.2 Orvis, Baby!
1953 Willys M100 trailer Tagalong
________________
[_][][][][][][][][_]
#4
Mickey_D is offline
post #4 of 4 Old 04-04-2009, 03:33 PM Thread Starter
alexsious
the regulator cable is attached to the motor. so i took the really hard route and unbolted it from inside the door. that took a few hours. but it works now! i can roll down my window!!!
But i would still like to know how to get the window down when you have electric windows. just a reference for the future.
thanx
Driver's Window/Door control are not working. Jim Holmes ZJ Grand Cherokee Forum 5 12-24-2008 09:18 AM
WK Front Driver's window glass replacement gamma500 WK Grand Cherokee & XK Commander Forum 4 07-19-2008 01:50 PM
01WJ Driver's window motor FordPrefect ZJ Grand Cherokee Forum 7 06-25-2008 04:35 PM
Driver's Side Window SkyjacktZJ ZJ Grand Cherokee Forum 24 03-20-2006 01:15 PM
Driver's side power window won't stay up. tchang ZJ Grand Cherokee Forum 6 08-30-2005 11:44 PM
