Gettin' Burned out on the ZJ! - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Gettin' Burned out on the ZJ!
Only 2 Days left to win $3,800 Jeep Parts!Count Down to KOH Sale!Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 09-21-2014, 03:26 PM   #1
ryanf77
1996 ZJ, 4.0, 4x4 - So... First My ZJ Burned up the PCM. I installed a new Crank Sensor and replaced the PCM with a Used unit and it burned it up. I then replaced the Crank Sensor, Cap & Rotor and Installed a Re-Man PCM and it burned it up. I then Replaced the Alternator and Both O2 Sensors and was able to put over 1,000 miles on it Now, Yay, right? Well, during this1,000 or so Miles it has been Idling High and then Normal and then High and then Normal and so on... Well, now out of nowhere it is stalling on me. Sometime it will just die and other times I can pump the throttle and save it and other times it will almost stall out and then recover on its own. I checked the Fuel Pressure and it stays consistent right about 50psi when it is running and when it stalls. I'm gettin' pretty tired of this thing! Fortunately it is just a toy and not a Daily Driver. Any Ideas of what to do from here? I Cleaned the IAC. I've wiggled all the Vacuum Lines looking for a leak, Jiggled the CPM Connectors. Is there anyone in Southern California that knows this vehicle and would wanna work on it???
ryanf77 is offline   Reply With Quote Quick reply to this message
Unread 09-23-2014, 06:15 PM   #2
ryanf77
Any Suggestions anyone? I bought a Noid Light Set that should be delivered tomorrow so that I can check the Fuel Injectors and see if they are being shut off or not when the Jeep Dies. Pending those results any ideas?
Unread 09-23-2014, 06:53 PM   #3
ZeeJay1997
see link below
ZeeJay1997 is offline   Reply With Quote Quick reply to this message
Unread 09-23-2014, 07:20 PM   #4
mikem350
1994 ZJ
First step for an OBDII car is scan for codes...don't even get your hands dirty!!
Proud owner of TWO 4.0 Laredos
Red 94 w/133k, mint!
Silver 98 w/249k runs as new!
mikem350 is offline   Reply With Quote Quick reply to this message
Unread 09-23-2014, 09:30 PM   #5
ryanf77
I agree on the OBDII Scan! Done it multiple times to make sure! No Codes...
ZeeJay, as for the List, I have seen it and read through it a couple times now. I have Done Numbers 1,3,4,5,6,8,9,10,&11. I did Part of # 7 also! I will do # 2, 12, & the rest of 7 and then let Ya know the results!
Unread 09-23-2014, 09:40 PM   #6
ZeeJay1997
if none of the other stuff pans out, sounds like something could be going on with iac. may have an intermittent short. no good way to check it with a meter (that i know of) other that take it off and see if the pins all read the same resistance to case. tap it with a screwdriver handle while it's running.
Unread 10-15-2014, 10:12 AM   #7
ryanf77
ZeeJay, I Checked that the Injectors were getting signals with the Noid Light and they all tested good. Also, with the Noid Light Set came a tester for the IAC and it is getting a signal/power. Just in case though, I replaced the IAC with an Airtex Unit and am still getting the same issue. Any more ideas?
Unread 10-15-2014, 11:38 AM   #8
PolkaPower
I'd only use Mopar sensors. The others are a crap shoot. Might be the TPS or MAP. Could be the new after market crank sensor if it's not Mopar. Might be the PCM again. I do know that when my TPS went bad it would lose throttle when I would accelerate and stall and bog at stop lights. Sometimes I could feather the gas and revive it other times not.
PolkaPower is online now   Reply With Quote Quick reply to this message
Unread 10-15-2014, 12:09 PM   #9
ryanf77
Thanks PolkaPower. I had heard/read that the Airtex was as good as OEM. I don't have a Dealer near me and Airtex is readily available on ebay so I went with it. I will replace the TPS and see what Happens...
Unread 10-15-2014, 01:50 PM   #10
PolkaPower
These are all possibilities. Right now you are just tossing money at it.
Unread 10-15-2014, 01:54 PM   #11
ryanf77
Yeah, I'm out of ideas except to just throw New Parts at it until I get it... I'd even take it to someone to fix it but don't know any Jeep Experts. Guess I could call the dealer and see about taking it to them. Dunno how experienced they'll be with a 1996 though...
Unread 10-20-2014, 11:24 AM   #12
ryanf77
Well... I installed the new TPS and still the same Symptons. Now, it won't start at All. Checked for Spark with an inline Spark Light and no Spark... What now???
Unread 10-20-2014, 11:46 AM   #13
dodgemahal
I've had pretty good luck with Airtex and Standard, so far(knock on wood). If you have no spark, same problem I have now, you have to haul out the manual and start testing all your ignition components......start there. I feel your pain dude.
dodgemahal is offline   Reply With Quote Quick reply to this message
Unread 10-20-2014, 12:08 PM   #14
PolkaPower
How about your battery ground?
Unread 10-20-2014, 09:47 PM   #15
ZeeJay1997
if you havent reworked the grounds, do so.
then it may be time for the nuclear option. carefully take the looms off of all the wires on top of the engine starting at the four that branch up to the throttle body. check for hardened/melted/fused insulation where the copper center has broken through and are touching.
