Gearshift Vibration on 1993 ZJ 4.0 - JeepForum.com
post #1 of 2 Old 05-09-2012, 04:51 PM Thread Starter
FREFLO
hello!
This is the background:1993 zj 4.0 automatic transmission 135,000 miles, no especial modifications, maintenance up to date, runs great. 5,000 miles ago, the automatic transmission was rebuilted, it works after the rebuilt. The engines mount and transmission mounts were shot, and were changed 1,000 before the transmission overhaul. There is where the vibration started. When i'm driving, at any speed or road condition, the transmission gearshift starts to vibrate A LOT, really A LOT . It feels like the transmission is going to fall apart (it doesn't). The transfer case gear shift also vibrates a lot. i have past trough 4 different mechanics, all of them have checked: The transmission, the engine and transmission mounts, front and rear suspension (it was completely changed 10,000 miles ago) and everything seems to be fine.
The transmission shifts gears correctly up and down. I really have no idea what's wrong, and i'm kind of desperate.
What is strange is that before the transmission overhaul, the ZJ had very poor MPG (11 MPG combined), after the fix; it's the same. Have done all the possible tune ups, spark plugs, cables, rotor, air filter, seafoam, oxygen sensors, new belt, thermostat, fan clutch(last 3 fixes were part of maintenance 3,000 miles ago). i don't want to hijack my own threat with the gas consumption but maybe it has something to do with the vibration/ transmission (???)
I am starting to guess there is maybe something wrong with the transfer case, i hardly use the 4wd (shame on me).
Any thoughts? Any idea would be appreciated!
Thank You!
FREFLO is offline
post #2 of 2 Old 02-21-2013, 09:35 AM Thread Starter
FREFLO
Update:found out it was the starter. I changed it and within one month the vibration and rattle was gone. Crazy thing that when removing the old starter, the bolts were tight!
Sent from AutoGuide.com Free App
FREFLO is offline
mpg , transmission mount , vibrations
1993 zj melinda87032 ZJ Grand Cherokee Forum 3 11-09-2012 05:01 PM
1993 zj at0micburn209 ZJ Grand Cherokee Forum 0 01-26-2011 02:50 PM
'98 - Backup lights. Adjusting Gearshift Cable Question. How To do it? Camaro11 ZJ Grand Cherokee Forum 7 10-25-2010 10:16 PM
How to clean/fix stuck gearshift sliding cover? nocluejimbo ZJ Grand Cherokee Forum 5 08-15-2009 04:34 PM
1993 zj, do I have the aw4? supniceyeah ZJ Grand Cherokee Forum 18 04-01-2009 04:22 AM
