Gears Question..... 4.10s to much??? - Page 4 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Gears Question..... 4.10s to much???
Build your Dream Jeep with Poison Spyder's Interactive GarIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineRuffStuff Memorial Day Sale!
Unread 03-06-2010, 09:55 AM   #46
Mike97ZJ
Originally Posted by torchd View Post
hahhaha I know right Mike... Still rockin' my stock 3.42s in the Trans Am..
Looks like all my money instead of going into the Trans Am, is going into the Jeep
I SO want 3.42's for mine, it's a A4. I'm rockin' 2.73's right now.
And I have the same problem, there are things I want to do to the Bird, but the money keeps going to the Jeep.
It's tough...it must be like a parent trying to pick which kid they like best, lol.
Mike97ZJ is offline   Reply With Quote
Unread 03-06-2010, 06:25 PM   #47
torchd
If I ever get 4.10s for my trans am, I will sell you my 3.42s cheap.. R&P has ~45K miles on it. not really beat on and the diff fluid changed...
torchd is offline   Reply With Quote
Unread 03-06-2010, 06:26 PM   #48
torchd
If you have your Jeep on a jackstands so the rear wheels can turn freely, if one wheels turns forwards and the other wheels turns in reverse is that Limites Slip?????
Unread 03-13-2010, 09:37 AM   #49
torchd
Still haven't called Randy's R&P yet been busy at work
Also jsut waiting for Patrick (rugermack) to get to me.. He has been busy to!
Thanks for all your help everyone
Unread 03-13-2010, 07:30 PM   #50
Mike97ZJ
Thanks for the offer. Will you be selling the whole carrier, or just the gears? I have a 2 series carrier, so I'd need that too.
I'm actually trying to find a whole rear out of a M6 car, I'd rather just swap the whole rear so I can do it myself as opposed to paying someone to do the gear swap.
An sounds like you have an open diff. With a LTD slip, the should both turn in the same direction when you spin one.
Unread 04-17-2010, 04:23 PM   #51
torchd
Still never got a chance to call Randy's R&P or CCOR... And I dropped the ball with Rugermack that was my fault. Work has been consuming me..
And now I think I have a bad pinion bearing (rear) going out. All the more to make me gets 4.10s now..
I need to find a carrier for the front that accepts 3.73s and higher.. Anyone know of anyone selling one?
Unread 04-17-2010, 04:29 PM   #52
torchd
What's the difference between high pinion and low pinion?
What does my 98 GC have?
Unread 04-17-2010, 05:13 PM   #53
WJ04
WJ04's Avatar
High pinion gears are reverse cut, they are not compatable with a low pinion axle.
2004 WJ Laredo-selectrac 242-I6- Custom XJ intake w/Amsoil cone filter- PSC HD Pump & Res- PSC ported box- B&M trans cooler- B&M PS cooler- Custom chevy 1 Ton over the knuckle steering- Rough Stuff 1 Ton tierod & draglink ends- Saguaro 4x4 Front 3/4" shackles, Rear hitch & Warn 3/4" shackle-Mopar Front skid,Gastank skid -IRO TC skid- RRO super sliders- 6.5'' IRO critical path lift -IRO extended rear arms-Bilstein 5125 shocks -IRO F&R 6.5'' Bump stops-Carolina drive shaft-16x7 black soft 8's - 34'' Super swampers-Yukon 4.11 gears -Ultimate RCV shafts - LockRight Locked ECGS bolt in rear D60 -35 spline Chomloy shafts -BTF HD diff cover -IRO Adj A-arm-OX Locked super D30 -OX HD diff cover -OX drive away lock-Rock Krawler d30 truss-Stillen rotors & Matrix pads-JKS Adj Track Bar-JKS Quicker discos -Relocated OME SD-40 Steering Stabilizer-BDS stabilizer brackets-Relocated washer bottle-Removed rear sway bar-Cobra CB-TomTom one XL navi-alpine deck
Still to come: Flowmaster 50suv
October 2011 GCOTM Winner
Some of my videos: http://www.youtube.com/user/LockedWJ?feature=mhee
Originally Posted by billyjp2 View Post
I burnout on puppies and kittens
Originally Posted by vwmaniacx View Post
Lets not and say we didn't.
WJ04 is offline   Reply With Quote
Unread 04-18-2010, 10:44 AM   #54
5.9 ANDY
zj tractor
5.9 ANDY's Avatar
high pinion axles ovver more strength on the housing under heavy load, and they offer better ground clearence...
you have a LP30 aka low pinion 30.
hard working private first class in the United States Marine Corps.
Originally Posted by shift_grind View Post
It's threads like this that make me wonder why people lift there jeeps
its comments like this that make me wonder why some people are jerks.
build thread:http://www.jeepforum.com/forum/f197/...ndard-1056365/
5.9 ANDY is offline   Reply With Quote
Unread 04-18-2010, 05:15 PM   #55
torchd
Hopefully when I get my 4.10s that they wont be noisey??
I still need to find a shop to install them
Unread 04-18-2010, 06:35 PM   #56
xJoshxx
2011 WK
they should be Silent unless you got bearing going bad.
hell i got 3.73's and i got 245/70/16's and wish i was at 4.10's
Interested in Amsoil? Sold4" Hybrid lift TeraFlex coils IRO Adjustable LA's Jks tracbar 1.25spidertrax spacers 265/75/16 Dura-tracs
Originally Posted by moPowered View Post
The SRt-8's are a liberty design.
2011 WK2 Laredo with ORA1
xJoshxx is offline   Reply With Quote
