Gear shifting problem - JeepForum.com
post #1 of 5 Old 08-25-2013, 01:19 PM Thread Starter
orangeafroman
I was going too fast on the 20-mile bumpy dirt road home yesterday, hit a bad bump at high speed.
Noticed the tranny not shifting after that as I sped back up. Stopped to figure it out, and couldn't put into park. Shifting it all the way up, it was in R. So I figured it out - the shifter was one gear off the whole way. P was R, R was N, N was D, etc. I had been in 2nd instead of Drive.
So I put it into drive (N) to get home. I pulled up the cover to the gear shifter. Now, it has plenty of dust in it, so if that's the issue, please tell me. But what caught my eye was a few wires connected to a circular end, but not plugged into anything. I looks like it should connect to something, but I don't see anywhere that would accept it. The wires come from the driver side of the area.
So does anyone know if that little circular harness should be plugged in? Where?
orangeafroman is offline
post #2 of 5 Old 08-25-2013, 01:52 PM Thread Starter
orangeafroman
The little harness plugged up into the white box, probably to illuminate the letters. I found a broken bulb at the bottom and took it out, hoping it would fix things. it didn't. The problem persists.
I don't know what I'm doing, just doing non-invasive things until your help comes.
post #3 of 5 Old 08-25-2013, 02:17 PM
RoldGold
There are write-ups regarding adjusting the shift linkage. I don't know for sure, but that certainly sounds like your problem. It's also in the FSM and probably in a Haynes or Chilton.
1996 Grand Cherokee Limited 4.0L
PSC Steering Gear; NP249 w/ new VC; Moog TRE's, Track Bar, Stabilizer bar bushings and endlinks, control arm bushings
Still no lift, and almost no paint on the hood
RoldGold is offline
post #4 of 5 Old 08-25-2013, 03:16 PM Thread Starter
orangeafroman
any info on that? general knowledge?
post #5 of 5 Old 08-25-2013, 03:49 PM
shaban
Theres a shift linkage adjustment thing located on the tranny -drivers side towards the bellhousing.
You'd need to unlatch it, shift the gears on both shifter and tranny to "park", and latch it.
Then check how the shifter looks like in each gear. If its a bit off, repeat the procedure with a bit different shifter position.
Also, check out this link:
http://www.jeepforum.com/forum/f11/a...-park-1125788/
shaban is offline
