Gear shifter console light - JeepForum.com
post #1 of 5 Old 03-06-2009, 03:59 PM Thread Starter
RangerJ
Hello folks,1999 GC 4x4 auto 4.0 (gas guzzler) Light in the gear shifter console is out, need info on how to replace the bulb or at least how to get to it.Thanks
RangerJ is offline
post #2 of 5 Old 03-07-2009, 08:43 PM
PA 5.9
Assuming it's like a ZJ, you carefully pry the bezel up and then pop the bulb out of the socket and replace it.
PA 5.9 is offline
post #3 of 5 Old 03-07-2009, 09:08 PM
Mickey_D
Are you talking about the little bulb that lights up the actual PRND21? It's a #129 bulb in the ZJ and is just like PA 5.9 said. In fact my bezel won't stay down. If I shift all the way into to L1 my bezel pops up out of the center console.
Once it's loose from the center console, the bezel just slides up the shifter and the bulb socket sticks out of the bottom. Twist the socket a little and it pops out, then you pull the bulb straight out of the socket. Reverse the process to put it back together.
1997 ZJ 5.2 Orvis, Baby!
1953 Willys M100 trailer Tagalong
________________
[_][][][][][][][][_]
#4
Mickey_D is offline
post #4 of 5 Old 03-09-2009, 04:47 PM
g-town ram
g-town ram's Avatar
I hope I'm wrong ,but I think my wife's was replaced under warranty and they had to replace the whole unit,it's a different kind of setup and uses higher voltage. I think that's what I remember.
Good luck
97 Black Sahara
(OlllllllO)
g-town ram is offline
post #5 of 5 Old 03-09-2009, 05:25 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
i'm pretty sure it's not just a bulb in the wj like it is in the zj. the zj uses 194 bulbs.
ratmonkey is offline
back light on gear shift console yellowtrumpet ZJ Grand Cherokee Forum 5 12-28-2008 03:40 AM
No backlight WJ gear shift console yellowtrumpet ZJ Grand Cherokee Forum 0 12-27-2008 02:55 PM
No first or fourth gear after center console removal and reinstall Killer Cougar ZJ Grand Cherokee Forum 0 07-24-2008 03:25 PM
Backlighting on Gear Shift Console Out Juanbjuan ZJ Grand Cherokee Forum 2 12-07-2007 08:41 AM
Shifter console machbrent ZJ Grand Cherokee Forum 1 05-19-2002 12:07 PM
