Gear pattern check - JeepForum.com
post #1 of 5 Old 05-15-2013, 07:53 PM Thread Starter
Einkley
Gear pattern check
Dana 44a
Backlash- .007-.0075
Ttr-31
Tttr-42/43
Einkley is offline
post #2 of 5 Old 05-15-2013, 08:02 PM Thread Starter
Einkley
And the other side...
Einkley is offline
post #3 of 5 Old 05-15-2013, 09:03 PM
framanda
Drive side Looks pretty centered root to face but slightly towards the toe. I just did my first gear set up so I am very new to this. but If i would have came up with that pattern I would pull .005 out from the pinion and if your backlash is a 7 now it will probably need to be reset. Are you setting the preload on the pinion bearings?
I also would like to say I have seen patterns like that run with no ill affect, but if your setting up your own I would take this as an opportunity to strive for perfection.
Some one with more experience may come along and say I'm wrong but that is my interpretation of what I have seen, and my small amount of knowledge on the subject.
framanda is offline
post #4 of 5 Old 05-15-2013, 09:16 PM Thread Starter
Einkley
Pinion preload was 31 in lb. This is my first setup too, I'm just surprised everything was so close the first time. I would like to try and get a seccond pattern, I feel like the first was done incorrectly, with no resistance on the pinion yoke, any tips?
Einkley is offline
post #5 of 5 Old 05-16-2013, 06:12 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
wrap a rag around the yoke real tight and tie it to a tube to get a good few dozen ftlbs of resistance when turning the ring gear. or use a wood block between the housing and ring gear when turning the pinion.
the pinion looks to be way too shallow on the drive side. i'd take the back lash down to .004 myself. the aluminum housing flexes quite a bit so you want it on the tighter side of things at initial set up.
ratmonkey is offline
