GC Tailgate Adjustment - JeepForum.com
post #1 of 2 Old 06-26-2004, 01:42 PM Thread Starter
mhouston
The tailgate on my 1998 Grand Cherokee Limited 4 x 4 is difficult to open. I have to fiddle with it to get it to release. Does anyone know what adjustments have to be done to fix this? Had the same problem on an 88 Cherokee too.
mhouston is offline
post #2 of 2 Old 06-30-2004, 12:48 PM
7thStranger
7thStranger's Avatar
Pulled off of another post.
"take off hatch interior cover.
remove 3 torx (T-45 i believe) bolts. Remove electrical connection & rod going to door handle. I use WD-40 and worked the lock loose for about 10-15 minutes. Sprayed more lubricant back in there and reinstalled. My wife is now able to open the rear hatch by herself once again.
Mine was stuck from old grease and dirt."
I have the same problem, going to try this.
Good luck.
7thStranger is offline
VIC 242 adjustment Dillonzj ZJ Grand Cherokee Forum 2 08-06-2008 04:44 PM
96 ZJ TPS Adjustment/Testing NYCXJ90 ZJ Grand Cherokee Forum 2 07-30-2007 09:05 AM
Caster Adjustment 94 ZJ dpierson ZJ Grand Cherokee Forum 4 06-04-2007 12:39 PM
WJ headlight adjustment Tdad ZJ Grand Cherokee Forum 0 12-16-2006 09:33 AM
Sway bar adjustment? TOM380 ZJ Grand Cherokee Forum 3 12-29-2004 08:13 PM
