gc 5.2 sputtering/bucking/backfiring - JeepForum.com
post #1 of 4 Old 06-01-2009, 06:43 PM Thread Starter
spikeystrip
1993 XJ Cherokee
i decided to give my 5.2 a tuneup a couple weeks ago so i went out and got basic plug wires, cap and rotor. i did it all and ever since then my jeep runs like ****. if i accelerate slowly it will buck and and backfire and it also does it when im cruising so its impossible to drive the highway. if i accelerate fast or floor it , it will run fine and strong. i do not have any lack of power by the way and i changed the wires but still has same symptoms. How can i test my tps? is there anything else that would cause these symptoms. thanks
1993 cherokee country.
Rustys 5inch lift
firestone 31x10.5 w/ cragar d windows
1995 Grand Cherokee
Stock Daily Driver
AWD 5.2 V8
spikeystrip is offline
post #2 of 4 Old 06-02-2009, 05:42 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
couting of the wires, improper gap on plugs, switched wires around possibly, or the wrong plug.
ratmonkey is offline
post #3 of 4 Old 06-02-2009, 05:51 AM
newfieZJ
X 2 , check your spark plug wire routing , confirm all the ends are snapped properly on the dist cap and spark plugs .
There is also a TPS for the plugs wires and how to route them properly , cheap parts may increase the chances of problems from this issue . Here it is http://dodgeram.info/tsb/1998/18-48-98/18-48-98.htm .
1995 Orvis build
1988 MJ build
1998 Slate 5.9 build
1998 Platinum 5.9 build
newfieZJ is offline
post #4 of 4 Old 06-02-2009, 09:03 AM
ZJPunk98
these guys are right....
Erik
98 ZJ 5.2L JGC Limited Sold
02 4.7L HO JGC Overland
ZJPunk98 is offline
Bucking, Sputtering, Wierd idle IAC motor, TPS, Im stumped?? jlcca844 ZJ Grand Cherokee Forum 42 09-30-2011 04:36 PM
Please help!!! 95 ZJ bucking and sputtering 95redlaredo ZJ Grand Cherokee Forum 8 08-01-2009 11:42 AM
04 JGC - 6cyl - bucking/sputtering...then vanished - help! pajeepguy ZJ Grand Cherokee Forum 10 12-20-2007 06:50 AM
94 Gcl Bucking When On The Gas ABSOLUTE LAND ZJ Grand Cherokee Forum 3 06-21-2006 12:01 AM
backfiring problem Saleen4971 ZJ Grand Cherokee Forum 3 03-09-2004 10:13 PM
