gauges going crazy and won't start - JeepForum.com
post #1 of 14 Old 05-15-2007, 02:04 PM Thread Starter
ZedMan2K
Hi all I am new to your forum and thank you for your love of Jeeps.
This is my second Jeep, first was a 84 G-Wagoneer when I was too young to 'use' it right (lol).
I now have a 00 G-Cherokee Lim. I love it and know I will be doing a lot of the good stuff to it
Now for my problem, on sunday I tried to start it and ALL that happened all of the gauges went nuts (jumping all over the place) with a clicking from behind the cluster. It did this even after I took the key out. The int. lights were dim and flickered with the clickin, if I hit the brake pedal it all stoped untill I let go of it. After a few presses it stoped and I could start the truck.
Today my wife had the Jeep and the same thing happened to her, just the brake thing didn't work so I drove out to her and pulled most of the main fuses and it started, but the Tac. and speedo were pined all the way around. I fixed that by pulling the cluster fuse.
Anybody have any idears? Can the gauge cluster keep it from starting? Could the CPS mess with the cluster??
ZedMan2K is offline
post #2 of 14 Old 05-15-2007, 02:08 PM
Briandl
Get your battery checked...
Briandl is offline
post #3 of 14 Old 05-15-2007, 02:21 PM Thread Starter
ZedMan2K
That was my first thought but it has always started strong and quick so I moved it down the list of possibles, still worth checking. Thanks
ZedMan2K is offline
post #4 of 14 Old 05-15-2007, 02:25 PM
Briandl
Well I've read the same symptoms here or on JU and it was a bad battery, and it's easy to check so move it UP the list...
Briandl is offline
post #5 of 14 Old 05-15-2007, 02:28 PM
mendelmax
definitely sounds like bad battery. It might have been destroyed while driving, for example on the bump. It happens sometimes. Check it first, before you disassemble half of the rig
POLISH JEEP OWNERS CLUB #11
Anyway, nothing will beat Suzuki :D
mendelmax is offline
post #6 of 14 Old 05-16-2007, 01:49 AM
BexarWolf
Similar thing happened to our '00 GC Laredo. It started but all the gauges pegged out to the max. Took it to the shop, found one of the lead plates in the battery had broken and was causing a short. New battery, gauges/starting fine.
BexarWolf is offline
post #7 of 14 Old 05-16-2007, 04:43 AM
clgielin
2003 WJ
I just had this problem recently. I replaced the battery and cleaned/checked both terminal clamps and chassis ground. Haven't had any problems since.
http://www.jeepforum.com/forum/f13/electrical-problem-prevents-engine-start-408538/
Chris
2003 WJ 4.7L
Build Thread Here:
Michigan Tech Jeepers #4
Utah JeepCrew #16
clgielin is offline
post #8 of 14 Old 05-16-2007, 02:16 PM
Othoni
I had the same problem as yours, turn out I had to replace the battery. Once I replaced it problem solved. If you can take your battery to an autozone and they will check it for free. If it's good just make sure the terminals are on tight cause if there not it will make your gauges o crazy.
00 WJ I6 4.0L 4x4,
FIPK Gen2,Borla Exhaust Magnaflow tip, Carsound Cat, 62mm TB,Alarm/Remote start,Tinted windows,Front and rear tow hooks,Hypertech programmer3. Addco rear and front sway bar, Hid's 8500k
Othoni is offline
post #9 of 14 Old 05-16-2007, 02:24 PM
ArloGuthroJeep
Mr. Hyde!
ArloGuthroJeep's Avatar
Anyone notice a theme here?
'14 WK2 Limited w/5.7L, ORAI, & Tow Package
ArloGuthroJeep is offline
post #10 of 14 Old 05-16-2007, 02:47 PM
highryder08
i could be totally wrong but the theme i see starting to occur is that the battery is dead......yes, no???
2000 WJ LTD. - 2in. BB. Pirelli Scorpion AT/R. Hella 500 Amber Fogs
2000 Black TJ Sport, 4.5in. Superlift, 33x12.5in BF Goodrich Mud-Terrain's, 15x10in Cragar Black Steelies, Mile Marker 9000lb. winch, Bestop Tire Carrier, Custom Made Rear Bumper, Hella 500's, ARB Snorkel, Uniden CB/PA, SOLD
Appalachin State Mountaineers- Back to Back to Back National Champions!!
Go Noles!!
highryder08 is offline
post #11 of 14 Old 05-16-2007, 02:49 PM
LeroyJMC
1994 ZJ
What was your methodology of reasoning to come to this conclusion? Are you sure that your conclusion is accurate?
2009 Red Rock JK Unlimited Rubi
2006 Scion xA
1999 WJ Limited Quadradrive V8
1997 Chevrolet Z71
1994 ZJ Laredo 4.0 - Sold
Thanks for the IR Remote Smokinbk.
LeroyJMC is offline
post #12 of 14 Old 05-16-2007, 04:28 PM
str8shooter
I just went through the same.Battery worked great,next morning keyless opened the locks but nothing but gauges freaking out.I started to trouble shoot by 1st jumping it,which worked till I shut it off at work and it was completly dead again.Jumped it again and the checked the alternator......tested good.Shut it down and tested the battery and found it was shorted.Solution:got a new RED top optima and starts and works great and not a problem since.
Chris
Every time I look at my Jeep it cost me more money!
str8shooter is offline
post #13 of 14 Old 05-17-2007, 06:50 PM Thread Starter
ZedMan2K
Ok, I had the bat checked and it was ok, the Jeep will start after the all the gauges settle down,(pulling all main fuses and relays) and starts first shot, strong and quick. It has started no less then 20 times form the last time it acted up with no prob. The terminals are tight and clean. I'm hoping that it was just a glitch but will throw a new bat in just in case.
Thanks for the help
ZedMan2K is offline
post #14 of 14 Old 08-26-2015, 12:56 AM
wendymontoya
My jeep started just fine at 10:00 I left work wen't to walmart got a few items came out. Started my jeep and it died, I quickly started it again, it started, gave a little shake. Then i heard a pop under the drivers side dash and my check engine light went off. I was kinda happy about that, then i figured it was just a fuse. I had to make two more stops. I did not turn off the jeep when I got home I turned it off and tried to turn it back on. I have interior lights but nothing else. The gauges go crazy and my doors are locked and my remote doesn't work. HELP PLEASE
wendymontoya is offline
Gauges going crazy 88mudder WK Grand Cherokee & XK Commander Forum 33 03-29-2017 06:00 AM
4.7 Won't Start. Gauges going crazy. Islesfan079 WJ Grand Cherokee Forum 5 06-29-2010 12:25 PM
Gauges going crazy! FatAlbert ZJ Grand Cherokee Forum 6 07-26-2007 12:45 AM
Intermittent no start, gauges go crazy on 99 GC Help! B25Boxer ZJ Grand Cherokee Forum 5 07-23-2007 05:16 PM
Gauges going crazy dsgnomite ZJ Grand Cherokee Forum 1 01-21-2004 05:02 PM
