gauges dont work - JeepForum.com
post #1 of 6 Old 11-26-2011, 02:16 AM Thread Starter
98zjay
gauges dont work
98 zj limited ......so i pulled my whole dash apart and checked every connection. i even checked the main logic board behind the gauges and theres no loose or coroded connections. i checked my bcm connection theres nothing bad there. my gauges just wont work. they used to come off and on now they just dont come on at all. i have power to my dash my abs light stays on. what could this be? new bcm? or what??
98zjay is offline
post #2 of 6 Old 11-26-2011, 02:55 AM
newfieZJ
My guess would have to be the ignition switch if the jeep runs fine otherwise .
1995 Orvis build
1988 MJ build
1998 Slate 5.9 build
1998 Platinum 5.9 build
newfieZJ is offline
post #3 of 6 Old 11-26-2011, 11:12 AM Thread Starter
98zjay
That's an idea. How is that replaced
2000 tj 4.0 nv3500 5spd 2"bb+1.25 bl 33x12.5 MTR's Dana 44
98 zj 4.0 stock
98 ZJ 5.2L 4.5" IRO w/ 32" km2's and lots of goods-sold
98zjay is offline
post #4 of 6 Old 11-26-2011, 05:35 PM
chrisbean
just a thought, this happened to my buddys jeep. Check the battery cables, terminals. His was kinda corroded..didnt look like it was even anything to think about.I tapped them and twisted them a hair and everything worked?
chrisbean is offline
post #5 of 6 Old 11-26-2011, 10:57 PM Thread Starter
98zjay
I was having a problem with my batt terminal being loose at the same time this starting happening. Where as I always had to twist the terminal for connection and I always had no power. But I now have a new battery and terminals and it still won't work. Could it have fried something from resetting all the time
98 zj 4.0 stock
98zjay is offline
post #6 of 6 Old 11-27-2011, 09:41 AM Thread Starter
98zjay
I also do not get a chime when I turn my key to on. I do not hear those 3 tones and none of my dash lights appear before I turn my key to start so ignition makes some sense
98 zj 4.0 stock
98zjay is offline
lights dont work? lbgreenroom ZJ Grand Cherokee Forum 0 10-05-2011 05:16 PM
gauges going wack! windows wont work and gauges dont work nickwygant ZJ Grand Cherokee Forum 2 09-26-2011 09:49 PM
gauges dont work fuse keeps blowing cata123 ZJ Grand Cherokee Forum 6 08-01-2010 12:49 PM
Headlamps dont work!! sunflash2012 ZJ Grand Cherokee Forum 4 08-26-2007 06:54 PM
Fog lights dont work FivePointTwo ZJ Grand Cherokee Forum 8 05-15-2006 03:56 PM
