Gas question - JeepForum.com
post #1 of 22 Old 12-31-2005, 07:30 PM Thread Starter
the rock
Gas question
Good evening guys.
Fast question I took my 2000 grand Cherokee to the dealer because it was shaking little bit they check it out and said there was nothing wrong with the car that I was using the wrong gas. I was using 93 or 92 they said to me to use just 87 nothing else is this true? When I use 92, 93 I feel the car has much more power when I use 87 I feel the car has no power. What do you guys think what's the best gas to use on 2000 grand Cherokee. Thank you
the rock is offline
post #2 of 22 Old 12-31-2005, 07:33 PM
///BHRpowered
///BHRpowered's Avatar
I believe its the same as the zj, use regular, or 87-89 depending where you live.
The car will SEEM to have more power because of the higher combustion, however the ecu and exhaust is not designed to deal with it, so you get knocking issues, not to mention your "burning up" parts of the engine and emissions, just like the reverse is true on cars using prem, you end up "gunking up" the engine and choking the emissions.
I think you'll find that once you stick with regular the car will be much better off.
"A dark and bitter chill fills the air. once thriving life wallows away into ash as he slithers past, the very stars themselfs part to make way for his haunting, yet oddly claim arrival. Bhr approaches." - Hatter
"But i have to say, BHR's rants go hand in hand with moring coffee to get my day started - RXL"
Admin -
///BHRpowered is offline
post #3 of 22 Old 12-31-2005, 07:34 PM
anticrombie
anticrombie's Avatar
Shaking from using to high of a grade of gas?! I've never heard anything of that sort! Maybe if you we're throwin in 113 instead of 87, but I have trouble believing it from 92.
I see no spell check....
Charlie
anticrombie is offline
post #4 of 22 Old 12-31-2005, 07:39 PM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
Can you better describe the shaking?
Hunter
04 4.7 HO, limited
04 4.7 HO, Overland
08 Z71 Suburban, front leveling kit with rear spacers. 285/65 18s Nitto TerraGrappler G2s
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
For your performance needs:
480.998.366
Texas ZJ1 is offline
post #5 of 22 Old 12-31-2005, 08:09 PM Thread Starter
the rock
The feeling the car has is when i am sitting at a light, the car will have a shake to it. Kind of like when you have a rough idle or idle problem. My idle is fine though, so what else can it be. So it is posible that the high octane 93, can do harm to my angine.
the rock is offline
post #6 of 22 Old 12-31-2005, 08:40 PM
guango88
Air Trans
guango88's Avatar
conbustion chamber might need some clean up!
ONE ABOVE ALL
guango88 is offline
post #7 of 22 Old 12-31-2005, 10:45 PM
gkbid
Just a thought, I know you said the idle is fine but you might want to try cleaning the IAC... it's not expensive to do and has been known to correct rough idle conditions.
2004 WJ Limited Overland
4.7L HO, Black, 4X4 QuadraDrive w/Vari-Loks
Past Jeeps: 2001 WJ 4.7 Ltd / 1999 WJ 4.7 Ltd / 1993 ZJ 5.2 GW, 1988 XJ 4.0 Ltd
gkbid is offline
post #8 of 22 Old 12-31-2005, 10:55 PM
Reswob
Originally Posted by the rock
Good evening guys.
Is your WJ a 4.0L? That would explain the lack of power
'11 WK2 Limited 5.7
Looking for a WK2 full size spare tire and 18" rims
Reswob is offline
post #9 of 22 Old 12-31-2005, 11:00 PM
Meerkat
Using fuel with a higher octane rating than required by the manufacturer can adversely affect engine performance.
Warren
Black 1996 5.2L ZJ Limited
Meerkat is offline
post #10 of 22 Old 12-31-2005, 11:06 PM
jeepsterguy
2011 WK
http://www.quiktrip.com/gasoline/myth.asp
http://www.quiktrip.com/gasoline/toptier.asp
Try a top tier gas for a while, they are going by better standards than others.
They are also capable of cleaning dirty systems up.
jeepsterguy is offline
post #11 of 22 Old 12-31-2005, 11:12 PM
///BHRpowered
Umm, just use the gas thats required, its cheaper (not by much but still) and its what the car is designed for. Its really not the best idea to go against the simpliest of basic auto design and specs. The highest grade gas you can get in the U.S is I believe 96, with most stations sticking to 93. Octane booster may get you to 101, 113 is insane. Try the regular gas for awhile and after 2 tanks or so it should work itself out
Admin -
post #12 of 22 Old 12-31-2005, 11:14 PM
Meerkat
Here is the TSB that addresses the problem:
Engine - High Driveability Index Fuels
NO: 14-08-97
GROUP: Fuel
DATE: Nov. 21, 1997
SUBJECT:
Poor Driveability With High DI (Driveability Index) Fuel
MODELS:
1996 - 1998 (AB) Ram Van/Wagon
1996 - 1998 (AN) Dakota
1996 - 1998 (BR/BE) Ram Truck
1998 (DN) Durango
1996 - 1998 (FJ) Sebring/Avenger/Talon
1996 - 1998 (JA) Cirrus/Stratus/Breeze
1996 - 1998 (JX) Sebring Convertible
1996 - 1998 (LH) Concorde/Intrepid/LHS/New Yorker/Vision
1996 - 1998 (NS) Town & Country/Caravan/Voyager
1996 - 1998 (PL) Neon
1997 (PR) Prowler
1996 - 1998 (SR) Viper Roadster/Coupe
1997 - 1998 (TJ) Wrangler
1996 - 1998 (XJ) Cherokee
1995 - 1998 (ZJ) Grand Cherokee
SYMPTOM/CONDITION:
Long cold start times, warm-up sags, hesitations, and driveway die outs. These symptoms are most noticeable and severe at moderate ambient temperatures between 4 - 27 degrees C (40 - 80 degrees F).
DISCUSSION:
Gasoline with a high Driveability Index (DI) can cause the above described symptoms. DI is a measure of the gasolines total volatility, or tendency to vaporize completely. A high DI number is less volatile than a low DI number. Most premium gasoline sold in the U.S. has a higher (worse) DI index than regular or mid-grade gasoline. Use of premium gasoline is NOT recommended for vehicles designed to run on 87 (R+M)/2 regular or 89 (R+M)/2 midgrade gasoline. High DI gasolines also cause higher emissions for the same reasons they cause driveability problems.
For vehicles that require an octane rating of 91 (R+M)/2, premium is recommended, or possibly required. Using premium fuel with a higher than recommended octane rating is not recommended. Owners who experience fuel related cold start and warm up driveability problems should try a gasoline with the recommended octane rating or different brands of gasoline until they find one that provides good performance.
The octane quality of gasoline is only a measure of its resistance to spark knock. The use of higher than recommended octane gasoline under normal operating conditions does NOT improve startability, idle quality, fuel economy, driveability, acceleration, engine durability, or emissions. In fact, most higher octane gasolines available in the U.S. have higher DI values than regular gasoline. Customers are most likely to experience poor driveability with premium gasoline than with regular.
Some vehicles, such as Viper, Prowler, 5.9L Grand Cherokee, 2.0L Turbo Talon, and 2.0L DOHC Neon have been specifically designed to take advantage of higher octane. These vehicles may have higher compression ratios, and/or more aggressive spark calibrations which provide optimum performance with the specified higher octane. However, other vehicles which are not specifically designed and calibrated to take advantage of higher octane will not benefit from higher octane.
Some vehicles may experience light spark knock in situations such as trailer towing or climbing steep sustained grades. Light knock or "ping" under these conditions is not harmful. However, if the customer is concerned about light knock under these circumstances, the use of 89 (R+M)/2 or even 91 (R+M)/2 premium gasoline may be temporarily warranted. If a vehicle is experiencing heavy spark knock on gasoline with its designed octane rating, this may be an indication of excessive combustion chamber deposits, or some other problem. Combustion chamber deposits can be removed with Mopar Combustion Chamber Conditioner p/n 04318001. Standard diagnostic procedures may help in identifying other potential causes of excessive knock.
Some gasoline marketers may advertise that their premium gasoline contains extra detergent additives. Under provisions of the Clean Air Act, ALL gasoline sold in the U.S. must contain effective deposit control additives. Nevertheless, if fuel injector or intake valve deposits are suspected of contributing to poor performance, occasional use of Mopar Fuel Injector Clean Up p/n 04549613 is a much less expensive way to maintain engine cleanliness than regular use of premium gasoline.
The charts (Figures 1 & 2) show the negative effects of high DI fuel as related to customer satisfaction.
If fuel quality is suspected in causing a customers driveability concern, your zone technical office may be able to provide direction on procedures for fuel sample analysis.
POLICY: Information Only
Warren
Meerkat is offline
post #13 of 22 Old 01-01-2006, 12:41 AM
jeepsterguy
2011 WK
The US requirement is a minimum. Plenty of room for improvement.
http://www.toptiergas.com/
post #14 of 22 Old 01-01-2006, 12:44 AM
Woody
Retired back to Bowties
Woody's Avatar
1985
Always room for improvment. Why lead the way? All that gets you is higher costs.
Woody
1985 1 ton K-5, Detroit diesel, 36" tires (going bigger when money permits), 4-speed manual swap, Rockwell T-case, Hybrid lift, 12.5K winch.
Woody is offline
post #15 of 22 Old 01-01-2006, 08:24 AM
Meerkat
Chevron is about the only brand on that list that I have seen around here, and their stations are in such disrepair I would worry about water in the gas...
I normally buy Exxon (very common in these parts), but now I am concerned that they aren't on the list of top tier vendors.
Warren
Meerkat is offline
Newbiee Question?? - grand cherokee thumping question geoff6194 ZJ Grand Cherokee Forum 2 03-23-2011 01:59 PM
Radio code question - option question... GARover WK Grand Cherokee & XK Commander Forum 5 12-25-2009 10:39 PM
Noise question and Beach wheeling question bimmerjeeper ZJ Grand Cherokee Forum 4 10-06-2008 10:31 PM
air condition face unit question n00b question Fatsooo ZJ Grand Cherokee Forum 4 09-21-2008 08:45 PM
couple minor questions. door question and mirror question Irish_Assassin ZJ Grand Cherokee Forum 2 07-04-2008 02:14 PM
