Gas Millage!! - JeepForum.com
post #1 of 16 Old 02-01-2007, 02:14 PM Thread Starter
H0miegwillikers
Gas Millage!!
i have a 95 grand cherokee with a lift and prformance mods... when i baught the jeep a year ago i got about 280 miles to a tank, can anybody tell me why im getting about 200-220 to a tank now?? thanks!
H0miegwillikers is offline
post #2 of 16 Old 02-01-2007, 02:25 PM
AgitatedPancake
lift and performance mods.
To contact me, email
01 WJ 5 Speed Claytons LA's, 36" Iroks, 35 spline 9" rear, Custom Ruffstuff 60-9" front axle.
Build Thread:
AgitatedPancake is offline
post #3 of 16 Old 02-01-2007, 02:49 PM
GCherokee2001
Umm yeah, you just made your rolling brick taller and trying to throw it faster against the wind. It takes a little more effort and gas to move your lifted brick thus the reduction in MPG. :-)
Take the mods and lift off, and watch your mpg magically reappear!
2001 Grand Cherokee Laredo 4x4 (His)
-Stock
1997 Grand Cherokee Laredo 4x4 (Hers)
- Rancho RS9000's
- BFG All-Terrains 235/75 R-15
- Flowmaster Exhaust
- K&N Filter
GCherokee2001 is offline
post #4 of 16 Old 02-01-2007, 03:02 PM
FPKites
ZJjazzyJim
FPKites's Avatar
Depends on the performance mods as well.
When's the last time you did plugs/cap/rotor/wires?
Mopar combustion chamber cleaner can work wonders
I like BG44k
The list goes on and on. It's a Jeep. Jeep and fuel economy don't go together...and when you put modifications into the equation, those two words get farther and farther apart.
Jim Karlin
"Duh! Big RED Jeep!!!"
or
96 ZJ Laredo
5" lift, Claytons, KOR radiator support, rear bumper, steering brace, etc, etc, etc.
04 WJ Overland
Clean.... :D
FPKites is offline
post #5 of 16 Old 02-01-2007, 05:06 PM
sayc0002
Yikes 200-220 a tank? I was getting that much until I changed my o2 sensor and did a full tune-up (plugs, wires, coil, etc). Now I'm getting 320 miles from about 20 gallons even through below 0 degree weather which is about 16 MPG. BTW my jeep is completely stock..
sayc0002 is offline
post #6 of 16 Old 02-01-2007, 05:06 PM
Texas WJ
Texas WJ's Avatar
2005 WK
Winter blend gasoline can also impact mileage.
Texas WJ is offline
post #7 of 16 Old 02-01-2007, 10:58 PM
QuadraTokn
QuadraTokn's Avatar
1930 WJ
in a recent thread someone said this doesnt effect gas mileage
NEW Dana 44a Axle Truss and Skid !
WJ Grand Cherokee Tube Doors For Sale !
ZJ Grand Cherokee Tube Doors For Sale !
PARTS FOR SALE from 10 WJ Grand Cherokees ! !
QuadraTokn is offline
post #8 of 16 Old 02-02-2007, 04:44 AM
zjeepin
zjeepin's Avatar
Mopar CCC boosted my gas mileage along with a tuneup and some Redline Complete Fuel System Cleaner
97 ZJ Chop Top-Buggy 5.2L V8, 249 T-Case
5" Lift, JKS Front and Rear Adj. Trackbars, RE Twin Tube Shocks, RE T-Case Drop, Cut Fenders, Chop Top, Half Doors.
33"x13"x16" Super Swamper TSLs on Black Steelies
Custom Rack, 4 Roof Lights, Roof Back-up Lights
zjeepin is offline
post #9 of 16 Old 02-02-2007, 07:46 AM Thread Starter
H0miegwillikers
thanks for the feed back, the performance mods were already on the jeep as well as the lift when i bought it, i recently changed the plugs and ignition coil, but not a full tune up. i also used a mopar fuel system cleaner, so i guess the next thing to do is plug wires and c0 sensor.... btw, taking off lift and performance mods is NOT an option. Thanks!
post #10 of 16 Old 02-02-2007, 07:53 AM
PlatinumZJ
Senior Moment Member
PlatinumZJ's Avatar
tire pressure. check it.
extra weight. take it out.
lead foot? no cure.
Doug
When all is said and done, more is said than done.
Platinum '97 ZJ LTD, I6 (see profile) Paid for!
Links:
for ZJ & WJ stuff,
for performance stuff. I6 performance info at
Other stuff: Kevin's Roof Rack. KOR sliders, Bored 62mm TB, Blaupunkt Bermuda w/ ipod, Brembo Slotted rotors,
OME steering stabilizer, H4 headlight upgrade...
PlatinumZJ is offline
post #11 of 16 Old 02-02-2007, 08:05 AM
nitecop
Wheel bolt circle?
Increasing the tire height without correcting the speedo will make the miles lower. Even if the MPG did not drop it will seem so on your calculations.
Jim
USW, OAPSE Union member
99 TJ Sahara 4.0 5-Sp FUV + farm worker
Project f-Xj F150/XJ Ford eXtreme jeep combo
06 6 Speed LJ my daily driver.
Colorado Jeep club memeber #505
nitecop is offline
post #12 of 16 Old 02-02-2007, 09:12 AM Thread Starter
H0miegwillikers
just got new all terrains and checked pressures about a montch ago, just had over 150lbs of stereo equipment stollen at a skins game about 2 months ago and ive actualy been goin easy on the gas pedal and still nothing. i just filled up 2 days ago and got 204 miles on 22 gallons!! im goin broke!!!
post #13 of 16 Old 02-02-2007, 09:34 AM
nitecop
How laong has it been since it had new plugs?, injector cleaner used?
These things make my TJs Mpg jump from 16.5 right back up to a usual 19.5 .
Jim
nitecop is offline
post #14 of 16 Old 02-02-2007, 09:44 AM Thread Starter
H0miegwillikers
somewhere around 5 months ago... its due for an oil change so ill do that when the weather clears up but i doubt that will effect my millage too much..
post #15 of 16 Old 02-02-2007, 11:13 AM
zjeepin
zjeepin's Avatar
You need to do a full tune-up. Cap,rotor,wires,plugs. As well as before you do it do a search for a thread on how to use Mopar Combustion Cleaner. Get that from your dealership and clean your throttle body. Then go to autozone and get Redline Complete Fuel System Cleaner and run that thru your first full tank of gas after doing your tuneup and cleaning your TB. That should help you.
zjeepin is offline
High Millage Question? KRIZB ZJ Grand Cherokee Forum 19 07-21-2009 12:43 PM
Air Filter and Spark Plugs (gas millage) jakewalczak ZJ Grand Cherokee Forum 6 01-06-2008 04:05 PM
Gas millage... duzytata ZJ Grand Cherokee Forum 27 11-10-2006 05:25 AM
