Garbage pcm replacement companies - JeepForum.com
post #1 of 4 Old 04-24-2013, 02:52 PM Thread Starter
technophat
I tried AllComputerResources and CarComputerExhhange, and BOTH were an epic fail. After not being either "flashed" correctly or simply being a faulty unit, both companies had to send out a replacement for the replacement, and all four total units failed. Kolak set me up with a factory replacement and it worked on the first try. Kolaks pcm was about $200 more, but worth it for a working jeep.
1997 ZJ Laredo, 4.0, 42re trans, 242 T-case
1994 ZJ Laredo, 4.0, 42re trans, NP231 T-case
technophat is offline
post #2 of 4 Old 04-25-2013, 08:01 AM
FAlfani81
i have a computerexchange in mine. had it for 2 years with no problems. Tho, I did have to send back the first one. The bolt for the harness pulled right out of the board when I was installing it.
FAlfani81 is offline
post #3 of 4 Old 04-25-2013, 08:25 AM Thread Starter
technophat
Unfortunately, I was in Afghanistan when all the pcm troubles were happening, but my wife was coordinating with a local repair shop in Phoenix and they confirmed the poor results. It seems hit and miss at best with the non-OE replacements
post #4 of 4 Old 04-25-2013, 09:53 AM
jeepkid945
Mines a BWD from advanced no problems yet. Its even waterproof!haha
jeepkid945 is offline
