Garage door height to fit lifted ZJ? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Garage door height to fit lifted ZJ?
Engo winches available at www.rockridge4wd.com! Free shippOur 2014 DynoMax mail-in rebate March1- June 30th is here!OPTIC ARMOR WINDOWS all sale now !!!!!!!!
Unread 03-08-2014, 11:08 PM   #1
FastSUV
I am building a house and am considering adding 1ft to the garage door height.
My current house has about a 7ft tall garage opening and my 2" lift with 265/75's and a roof rack leaves me maybe 6-10" of clearance if i had to guess. I would like to do 285/75/16's and maybe a 4-5" lift. Considering I plan to always have some sort of roof rack, do you guys think I need to go ahead and upgrade the garage door height??? I would hope 8ft would be enough....what do you guys with lifted Jeeps do???
Truth be told, If I could get away with not having the taller door then I would but I don't want to build a new house only to later not be able to fit my Jeep in the garage!
ZJ - 5.9 Limited
WJ - 4.0 Laredo
WJ - 4.7 Laredo
FastSUV is offline   Reply With Quote
Unread 03-08-2014, 11:13 PM   #2
xcaliber81
1994 ZJ
May as well just do it now it will be so much cheaper. Lol I can see that now **** my jeep dont fit anymore.
Im indian my elders name is Jeep Grand Cherokee, I mean Chief Grand Cherokee. Quoted from Peter Griffin.
xcaliber81 is offline   Reply With Quote
Unread 03-09-2014, 01:36 AM   #3
1998_ZJltd
if you have the option .. a five panel roll up is really nice .... puts you just a bit over 8 ft I think ... wish I had that option ... but house was already in drywall stage when we bought ...
1998_ZJltd is offline   Reply With Quote
Unread 03-09-2014, 09:25 AM   #4
T-nave
I have a 4" lift and 33s and I can fit in my 7' door with a little to spare. If I was building a house I would go with an 8' door though in case I ever got another k5 blazer.
9er, 3.5 IRO lift + 3/4" spacers w/ adjustable trac bars and arms, 242 swap, 285/70/17 Duratracs and some other doo dads
T-nave is offline   Reply With Quote
Unread 03-09-2014, 10:07 AM   #5
riot1987
Location: In your attic, with the squirrels and wrapping paper
I hang garage doors for a living and in my opinion I think the extra foot is worth it if you have the option
http://www.jeepforum.com/forum/f22/riots-97-grand-1436100/
^build thread^
riot1987 is offline   Reply With Quote
Unread 03-09-2014, 10:15 AM   #6
WhiteOut
WhiteOut's Avatar
You'll never regret getting a larger garage door. Go with 8'
And riot: Is it possible to modify an existing track to get a garage door to raise that last few inches that it hangs down when it opens?
WhiteOut is offline   Reply With Quote
Unread 03-09-2014, 10:42 AM   #7
riot1987
It should go all the way up with the current track.. Does it have an opener? You can get new track for sure if you need it and if you have the room. Post a pic. Sometimes depending on the garage, they go with what is called low headroom track. If youre tight on space options are a bit limited.
Let me see your garage
^build thread^
Unread 03-09-2014, 02:14 PM   #8
1998_ZJltd
take a look at your opener .. you should be able to adjust it for the lift travel ... you may need to adjust your lift thrust also ...
Unread 03-09-2014, 07:26 PM   #9
FastSUV
Thanks for the replies fellas! I am waiting on a quote to add that to my plans but I saw a finished house today with the 8ft door and the guy had a lifted F250 so it was obvious why he opted for the taller door...As long as I can afford it, I'm gonna do it!
ZJ - 5.9 Limited
WJ - 4.0 Laredo
WJ - 4.7 Laredo
Unread 03-09-2014, 09:23 PM   #10
1998_ZJltd
if your in the pre build stage it should not be much ... the door side rails, five panel door vs 4 ... likely going to need 1/2 hp opener not a 1/3 due to the weight and a little larger spring .... I would not think more than a couple hundred diff .... maybe three ....
Unread 03-09-2014, 09:31 PM   #11
xcaliber81
1994 ZJ
lol screw the 1/2 hp go with a full 1 hp
Unread 03-09-2014, 09:38 PM   #12
riot1987
HA^^ Youd be amazed how strong even a 1/2hp motor is
^build thread^
Unread 03-09-2014, 09:39 PM   #13
riot1987
garagedoorforum.com
^build thread^
Unread 03-09-2014, 09:41 PM   #14
xcaliber81
1994 ZJ
i like even numbers lol.
Unread 03-10-2014, 12:59 AM   #15
Uniblurb
Uniblurb's Avatar
Ahh, so if you're going for power you might as well buy this gas engine "Blender Blaster" for parties!
96 4.0 ZJ Laredo, 2004 4.7L WJ Limited, 93 4.0 XJ (spare), 96 4.0 XJ (son's)
-Stalling ZJ? 12 things to check before replacing a sensor; the Dirty Dozen
-Crankshaft position sensor multimeter test. & video of testing.
Uniblurb is offline   Reply With Quote
