Fumoto oil pan drain valve? - JeepForum.com
post #1 of 17 Old 06-22-2010, 07:21 PM Thread Starter
metalhead
2011 WK
Has anyone used a fumoto valve to replace the oil drain plug? I use to get the fram sure drain and have used it on my last 4 vehicles and loved it. Made changing oil a lot less messy. I just found out that the fram sure drain was discontinued. So I saw this fumoto valve and was curious if anyone has used it?
Thanks
metalhead is online now
post #2 of 17 Old 06-22-2010, 07:30 PM
JesseOR
Just don't tell anyone you have it and don't piss them off. Lol.
Was the fram a screw-on tube that activated the valve?
Edit: just read it more, seems pretty good.
Like I said, don't piss someone off that knows you have it.
-Jesse-
GO DUCKS!
www.facebook.com/jesse.whitehargrove
JesseOR is offline
post #3 of 17 Old 06-22-2010, 07:42 PM Thread Starter
metalhead
2011 WK
Yes the fram had a screw on tube that activated the valve. It was a good system. So much better than openning the standard plug and hope you have the drain pan in the right spot. I use one of those pans thats a jug. You lay it flat and unscrew the large cap covering the hole for the oil to go into. Its not a huge openning so if its not in the right spot then oil goes everywhere. Especially if there is a little wind but its great in that it holds 12 quarts of oil so when its full I can dump it into an old 5 quart oil jug and take it to be recycled.
post #4 of 17 Old 06-22-2010, 09:44 PM
jcool1985
I am using the fumoto on my 4.7 01 wj. It is great I have had it over 2 years no problems. I have the one with the nipple for the hose just slip a short piece of hose on and put that in the pan. Drains fast and easy. I also put a stainless steel hose clamp over the opening lever so that it can't be moved or opened without using a flat blade screwdriver to remove the hose clamp first. It stays closed no problem without it but it is added piece of mind that it won't open on its own and makes it harder because someone has to have a screwdriver with them to open it. I recommend this hose clamp add on.
jcool1985 is offline
post #5 of 17 Old 06-22-2010, 10:16 PM
rm2001wj
rm2001wj's Avatar
Have had one on each of our 4.7 WJs, 01 and 04, for years. Got the ones without the nipple. Work well and with no mess. I wouldn't recommend them for off-roading because they might possibly get knocked off.
rm2001wj is offline
post #6 of 17 Old 06-23-2010, 06:46 PM Thread Starter
metalhead
2011 WK
Yea thats my only concern with it getting knocked off during offroading. The fram sure drain did not stick out nearly as far as I've seen the fumoto valve stick out.
post #7 of 17 Old 06-24-2010, 12:15 AM
jcool1985
I wouldn't worry about that. If you hit your oil pan hard enough to break off the fumoto valve I think you would have other damage such as a busted oil pan. After all the ones on the wj's aren't that thick just look at all the ones that rust through. Also you could always get a skid to protect the pan.
post #8 of 17 Old 06-24-2010, 06:48 PM Thread Starter
metalhead
2011 WK
Does anyone know if the mopar front skid plate would cover the oil pan area? I have read that only the transfer case skid plate is worth getting but if the front plate would protect the oil pan area it may be worth getting if I buy the fumoto valve.
post #9 of 17 Old 06-24-2010, 06:58 PM
rm2001wj
rm2001wj's Avatar
No, it will not cover the oil pan at all.
rm2001wj is offline
post #10 of 17 Old 06-24-2010, 07:04 PM
-Joe-
-Joe-'s Avatar
I have the fram suredrain.. Might check summitracing.com, they have other brands of them as well.
- Joe -
'95 Jeep Grand Cherokee Laredo I6 4.0L
242TC - Extreme Engineering 2" Front Lift/1.75" Rear Lift - ES9000 Shocks + JKS BPEs
Moog Cargo Control Springs
Magnaflow Converter - Dynomax Muffler
235/75/15 AT Uniroyal Liberator Tires
-Joe- is offline
post #11 of 17 Old 06-24-2010, 07:44 PM Thread Starter
metalhead
2011 WK
Oh yea I'll have to check that out thanks.
post #12 of 17 Old 05-03-2011, 01:42 PM
2511fj
1969 C101
I'm new to the forum and enjoy all the help everyone is willing to give.
Cheers
2511fj is offline
post #13 of 17 Old 05-03-2011, 02:14 PM
HighLonesome
Belief In All Things Jeep
HighLonesome's Avatar
Using this right now. Seals with 2 o-rings. I hope it never leaks.
http://www.rockauto.com/catalog/moreinfo.php?pk=1261489
HighLonesome is offline
post #14 of 17 Old 05-03-2011, 11:44 PM
GotMoose
1994 ZJ
I have the fumoto valve on my 94 zj. Had it for 2-3 year and no problems so far. It turns out that a 5qt oil jug fits just perfect under the valve, so I just use an empty one to catch the old oil and the leave it for recycling. No need to pour messy oil between different containers. I fill 6qt and lose about 1qt between oil changes.
GotMoose is offline
post #15 of 17 Old 12-09-2011, 08:54 PM
sxr951
yea but no magnet
sxr951 is offline
Radiator Drain Plug? Coolant wont drain epfriis ZJ Grand Cherokee Forum 6 06-18-2015 01:18 PM
Radiator drain valve? 93 ZJ 4.0 lawdogg ZJ Grand Cherokee Forum 19 06-04-2013 11:40 AM
Fumoto valve on 07 CRD HCG WK Grand Cherokee & XK Commander Forum 4 03-11-2010 08:28 PM
Fumoto oil pan drain plug Roughneck 6zero WK Grand Cherokee & XK Commander Forum 5 01-29-2008 10:02 AM
Fumoto Valve cherokee04 WK Grand Cherokee & XK Commander Forum 0 01-24-2007 01:08 PM
