Full write up of Built Jeep zj - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Full write up of Built Jeep zj
The Ruffstuff Optima Battery Box!The Cure for your Tie Rod Roll!Rockridge 4WD IS Taking Zone Offroad Suspension Lift Kits
Unread 02-24-2014, 01:31 PM   #1
JeepZJStroker
I drive a 1998 Jeep Grand Cherokee Laredo with 171k miles on it. It is an Inline 6 but with a twist, it has a fully built 4.6L Stroker engine.
This is the list of all the mods that i have done so far:
4.6 L Stroker:
4.2L Crankshaft
Hypereutectic pistons
3.895 stroke rods
.040 overbore
265 Duration camshaft
Ported intake and exhaust
LS1 valves
Bored out valve guides and seats
high flow oil pump
(there might be other things that i have forgotten)
engine has 6k miles on it and was built by Performance Concepts ( place i work at)
Jeep has a 2 inch Teraflex Budget Boost lift (spring spacers)
Skyjacker nitro shocks
Spidertrax wheel spacers/adapters from 4.5x5 to 5x5 bolt pattern
17" Moab Rubicon wheels
BFG Mud Terain tires 255/75R17 (32' tires)
Rear Dana 35 3.55 gear (stock and will be rebuilt and regeared to 4.10 soon)
Front Dana 30 4.10 gear Eaton Limited slip diff and everything else brand new with only 100 miles on it.
42RE 4 speed auto transmission
NP242 Transfercase
HID headlights
Custom built front bumper (currently not on)
Pioneer dash radio (not anything fancy)
Better sound Door speakers (not stock)
Kevins Offroad Radiator support with front D rings
There are many more things top come!
JeepZJStroker is offline   Reply With Quote Quick reply to this message
Unread 02-24-2014, 02:04 PM   #2
SCZJ
1994 ZJ
Did I read that correctly? You're running 4.10 gears in the front and 3.55 in the back??
'94 ZJ, 4.0, D30/D44A, 4 1/2" lift, 32" tires, 3.73 gears, etc...
www.twitter.com/ProjectZJ
SCZJ is offline   Reply With Quote Quick reply to this message
Unread 02-24-2014, 03:22 PM   #3
PolkaPower
Yes please explain how that is working
PolkaPower is offline   Reply With Quote Quick reply to this message
Unread 02-24-2014, 03:40 PM   #4
bigchieftaco
2005 WK
Probably keeping it in 2wd?
bigchieftaco is offline   Reply With Quote Quick reply to this message
Unread 02-24-2014, 05:01 PM   #5
SCZJ
1994 ZJ
Or the front driveshaft out?
Unread 02-24-2014, 05:06 PM   #6
riot1987
Professional Wise Guy
riot1987's Avatar
3.55's and 4.10's ...thats just silly
http://www.jeepforum.com/forum/f22/riots-97-grand-1436100/
Build thread^^
riot1987 is offline   Reply With Quote Quick reply to this message
Unread 02-24-2014, 05:07 PM   #7
riot1987
riot1987's Avatar
Your jeep looks a lot like mine though haha, same rims and color. Just slightly smaller shoes. I dig it brotha, fine taste
Build thread^^
Unread 02-24-2014, 05:12 PM   #8
Technohead
Old School
Technohead's Avatar
Technohead is offline   Reply With Quote Quick reply to this message
Unread 02-24-2014, 06:07 PM   #9
radean84
Maybe he's really good at doing wheelies
www.ProjectZJ.com Video Updates of my 96 ZJ
Follow me on Instagram @projectzj.c0m (with a zero)
radean84 is offline   Reply With Quote Quick reply to this message
Unread 03-06-2014, 12:20 AM   #10
JeepZJStroker
Guys, yes I am running 3.55 in the rear and 4.10 in the front! I just had my front end rebuilt and I put 4.10 gear and eaton LSD but didn't have enough funds to do both at the same time. Right now I'm keeping it in 2wd and my front driveshaft is out. In about a week the rear end will be pulled and also regeared to 4.10 and will have the eaton LSD in it also.
Also thanks a lot to everyone for comments on this build! I'll keep it posted as of the projects.
Unread 03-06-2014, 12:24 AM   #11
JeepZJStroker
quarter mile wheelies for days lol
Unread 03-06-2014, 08:03 AM   #12
Mark-318-IT
4.6 L Stroker:
4.2L Crankshaft
3.895 stroke rods
.040 overbore
LS1 valves
high flow oil pump
NP242 Transfercase
HID headlights
so sweet!
Mark-318-IT is offline   Reply With Quote Quick reply to this message
Unread 03-06-2014, 08:22 AM   #13
SCZJ
1994 ZJ
Sounds good so far. Should be a good thread.
Unread 03-12-2014, 07:24 PM   #14
JeepZJStroker
Well the time has come. The Jeep is in the shop once again with the rear Dana 35 pulled out. After opening up the diff cover, I thought I was going to have a heart attack lol, because each of the gears had quarter inch chunks missing out of them. Hopefully it will be done soon with new 4.10 gears and Eaton LSD I will keep you guys posted!
Unread 03-13-2014, 12:35 AM   #15
xcaliber81
1994 ZJ
I would have done the rear first but to each there own.
xcaliber81 is online now   Reply With Quote Quick reply to this message
built , cherokee , grand , jeep
