full time four tire question - JeepForum.com
post #1 of 8 Old 07-28-2011, 05:37 PM Thread Starter
jackedzj
1994 ZJ
so i know with the full time four zjs you cant have two types of tires it will blow the vc but i measured today from normal wear my tires differ by a 1/8 of an inch i just bought 4 bfg ats 33 two a brand new 1/2 in tread two are 1/4 how bad would that end and if i drop the front drive shaft will it cause any damage over time
~~~_______oooo_
~~ / ../...\...\_____\ The Big White Jeep
~~[_---_____---_\-\\\\\\-\
~~~(o) )-o---(o) )-o---) )
jackedzj is offline
post #2 of 8 Old 07-28-2011, 07:06 PM
FPKites
ZJjazzyJim
FPKites's Avatar
If you had a 96-98, I'd say pull the front shaft. Since you have a 94, I'd highly recommend not doing that. 93-95 249s don't do well with the front shaft removed (rolls in park).
There's a good chance that having 1/4" difference between front and rear will heat up your viscous coupler, but some have had good luck.
Food for thought.
Jim Karlin
"Duh! Big RED Jeep!!!"
or
96 ZJ Laredo
5" lift, Claytons, KOR radiator support, rear bumper, steering brace, etc, etc, etc.
04 WJ Overland
Clean.... :D
FPKites is offline
post #3 of 8 Old 07-28-2011, 08:07 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
1/4" tread vs 1/2" tread is a half in diameter difference. it'll eat the vc quickly. max difference is 3/8" diameter and even then it won't be happy about it.
ratmonkey is offline
post #4 of 8 Old 07-28-2011, 08:24 PM
iGotTheRunz
Food for thought.
You can pull the shaft without safety issues on a 1998? Could a shaft be the cause of some humming noise during acceleration?
iGotTheRunz is offline
post #5 of 8 Old 07-28-2011, 09:41 PM
FPKites
ZJjazzyJim
FPKites's Avatar
A little off topic there
Yes, a 96-98 NP249 can run without a front driveshaft with minimal wear.
The front driveshaft generally has 3 u-joints or 2 u-joints and a CV joint. Either combo can cause a hum, clank, etc when they get worn.
Jim Karlin
or
96 ZJ Laredo
04 WJ Overland
Clean.... :D
FPKites is offline
post #6 of 8 Old 07-28-2011, 10:38 PM
rlcii77
I've had my front shaft in & out & it'll be going back in in a couple weeks without incident, except, rolling on unlevel ground. I carry a chock block with me now.
rlcii77 is offline
post #7 of 8 Old 07-28-2011, 11:36 PM
sandman
just swap out the TC for a 231, thats cheaper than new tires.
1993 Jeep ZJ. 4.0
sandman is offline
post #8 of 8 Old 07-28-2011, 11:55 PM Thread Starter
jackedzj
1994 ZJ
Must agree with sandman that's my plan in the near future but the tires I bought brand new that are on the jeep it turns out that the super small difference is cause my phantom highway heat and pissing off the vc bad so I'm going to just find two more new bfg ats and stick with that route I do deliverys a lot and rolling isn't a good thing so the driveshaft drop is a no
~~~_______oooo_
jackedzj is offline
5.2 L V8 Full time 4WD ZJ Lift question. awakejeep ZJ Grand Cherokee Forum 4 06-20-2010 12:46 PM
242 t-case full time 4wd question (please help, about to swap) stainlessdreams ZJ Grand Cherokee Forum 11 05-20-2010 04:46 AM
99 Limited w/ Full-time 4wd question Kenl ZJ Grand Cherokee Forum 5 01-18-2009 09:35 PM
Smoking Diffs? Part Time/Full Time? azcoyote ZJ Grand Cherokee Forum 30 04-01-2007 07:29 PM
Full time 4wd locker question MoneypitGC ZJ Grand Cherokee Forum 2 04-24-2004 01:34 PM
