Fuel Pump - Removal from inside vehicle ? - JeepForum.com
post #1 of 12 Old 02-08-2011, 02:55 PM Thread Starter
Jon951
Understood: Metal cutting required
Here is the scenario and question...Fuel Pump bad...
Is it possible to remove the fuel pump assembly from the tank from inside the vehicle after cutting access hole in cargo area floor above the fuel pump?
I have a few sketches of the gas tank area and one thing concerns me. This being the possibility of a structural support member lurking under the sheet metal on the cargo floor in the location of the fuel pump assembly. Is this the case. If so, I imagine cutting this structural member would complicat things a great deal.
I just installed a trailer hitch (pain in the butt), and hear these pumps are notorious for failing. I though pulling the thing from inside the vehicle following sheet metal excavation would be a viable solution, as I could fabricate a simple patch to close the hole following installation of the pump. Theh vehicle is somewhat of a beater anyway, further supporting my approach. I figure if the pump fails again, the access, de-install and re-install of another one wuld be a cinch. Again, I am concerned about any structural steel under the shhet metal which wouldl block the pump assembly from being removed from the top of the tank. Any insight is appreciated.
Thanks Much
Jon951 is offline
post #2 of 12 Old 02-08-2011, 03:51 PM
ZeeJay1997
It has been done. I believe it's a matter of cutting the hole and fabricating an access panel. If it were me, I would use some seam sealer under the access panel.
ZeeJay1997 is offline
post #3 of 12 Old 02-08-2011, 04:16 PM
Yardman Harry
O
Yardman Harry's Avatar
Yes it can be done.... search swampy bypass.
This is unfortunately is a very lazy method. It doesnt take much to drop the tank. In fact you can replace your tank straps while youre at it so this way they dont rust out on you down the road. Leaving you stranded, on the side of the road.
Yard
Edit: the link is in the faqs
http://jeephorizons.com/tech/zj_fuel_pump.html
1996 Jeep Grand Cherokee. V8 - 5.2 litre 242 SelecTrac. SURCO Safari Roof Rack
Hunter Green
1997 Jeep Wrangler Sahara Ed. I6 - 4.0 litre, 4" SL, D44 rear, 4:56 Gears, AA SYE with double cardon custom rear Drive Shaft, IRO Adj CAs, Kevins Rear Adj TB with JOHNNY JOINT end
1999 Mazda Miata MX5 - Jet Black
1990 Jeep Cherokee Sport I6 - 4.0 litre
White
~Junked~
Yardman Harry is offline
post #4 of 12 Old 02-09-2011, 12:22 AM
rooster51
Sparks + gastank = BOOM!
BTW, your electrical wires for the pump are... guess where.
Just drop the tank.
Terry
rooster51 is offline
post #5 of 12 Old 02-09-2011, 01:42 AM
BlueDevil
Can be done - I did it myself, without even reading anything on internet, bcos I though nobody would do such a thing. It was on my Wrangler (YJ), and bcos of gas quality here I went through 4 fuel pumps in one year. Dropping the tank on YJ was pain, since it was always full and I had no garage to do it but had to do it outside.
Long story short - there is a saw that is driven by compressed air (air tools I think the call'em). It cuts, but doesn't make sparks since it's not electrical. I made a hole in the metal and then I cut with this saw. Didn't damage no wires bcos wires don't go towards the rear of the Jeep and so I started from there. Then I could bend the cut enough to take a peak inside and see where wires were, as not to cut them (this was after I made the firs of 4 cuts needed to make a sqare hole). So I did it, in like 30 minutes the hole was cut and enlarged enough so that the whole assembly could pass through it. Then I fabbed a cover from a piece of tin I had collecting dust in my back yard, I just cut it 1/2" larger than a hole, a couple of hits with a hammer, and made 4 bolts per side to bolt it all in.
To prevent smell inside, I used that self-adhesive thick tape you use to windproof doors in your house, I've put it around the hole and the bolts were outside of that. Problem solved.
A year after that, I changed another fuel pump on the highway, going to vacation, in about 15 minutes time, on the side of the road, using nothing but a screwdriver & a new fuel pump. That's how easy it was afterwards.
Beauty is in the eye of the beer holder
* 1994 ZJ (by VIN) with a 1995 engine (PO knows why)
BlueDevil is offline
post #6 of 12 Old 02-09-2011, 03:48 AM
Pugulis
And cutting metal never creates sparks or heat? Sorry, but I had to comment on this.
As for the access; I've seen people do this on allot of vehicles. It's almost always a waste of time. The reason I say this is, by the time you've measured and cut and then cut again because it's just a little off, you could have the tank dropped and put back in.
Pugulis is offline
post #7 of 12 Old 02-09-2011, 06:08 AM
BlueDevil
I know, but I test-drove it outside Jeep and it was moving way too slow to create any sparks.
I agree. And I don't Because as I said, I went through 4 pumps in a year, and I was SURE it wouldn't stop there. That one time - sure, cutting is more work than dropping the tank. But as I expected it to fail again - as it did - I think it was a wise move.
Another idea: mounting an external fuel pump and adjusting the existing pump assembly is very simple and it guarantees it's the last time you're dropping the tank... Alas, I found out about that way AFTER I've cut my YJ...
post #8 of 12 Old 02-09-2011, 06:30 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
Just drop the tank.
You need a specific fuel VAPOR density for gasoline to ignite. The liquid actually won't burn until vaporized.
It's not a big deal using a cut off wheel above the tank.
ratmonkey is offline
post #9 of 12 Old 02-09-2011, 04:25 PM
Pugulis
To be honest though, When the time comes for me to replace the fuel pump, I'll probably drop the tank and then cut an access hole. This way I have plenty of room and no chance of cutting something I wouldn't want cut.
Pugulis is offline
post #10 of 12 Old 02-09-2011, 05:54 PM
JeepOrvis97
JeepOrvis97's Avatar
That's probably a good idea but it only took me about 2 hours to drop my gas tank and I have a hitch and skid plate. Plus 2 of my hitch bolts broke their spot welds so I need to take my rear bumper off too while doing the repair. Basically my vote is to just do it the right way the first time.
Current jeeps:
1997 ZJ Orvis
1997 TJ 4.0L 5-speed
1993 YJ Sahara Trail Rig
JeepOrvis97 is offline
post #11 of 12 Old 02-09-2011, 05:55 PM
crosschecker
1995 XJ Cherokee
I like the idea of cutting the access panel, it seems like it would make things just a little bit easier. I had to cut the floor in my XJ to access the rear shocks, what's another hole?
'95 XJ 4.0, 2wd converted to 4wd, manual and stock
'96 XJ 4.0 Country, Auto (The new kid)(now in need of an engine)
'99 WJ 4.0, stock
'96 ZJ 5.2 Limited
crosschecker is offline
post #12 of 12 Old 02-09-2011, 08:45 PM
rooster51
This seems like the best idea.
Terry
New aftermarket high quality fuel pump? second pump in 3 years?!!!!? SPL Tech ZJ Grand Cherokee Forum 8 11-02-2010 05:12 PM
Fuel Pump Removal birdman891 ZJ Grand Cherokee Forum 5 08-21-2009 12:43 PM
made a tool for the plastic ring fuel tank pump removal sdowney717 ZJ Grand Cherokee Forum 3 04-19-2009 11:26 PM
WK: Diesely, burning smell inside vehicle bobholthaus WK Grand Cherokee & XK Commander Forum 58 11-16-2007 09:19 AM
Fuel pump removal/replace questions twmattox ZJ Grand Cherokee Forum 8 01-07-2004 02:38 PM
