Fuel pump relay location?? - JeepForum.com
post #1 of 5 Old 02-24-2010, 02:46 PM Thread Starter
littlefdl
1994 ZJ
either my fuel pump or fuel pump relay is going bad. pump doesnt run when i turn the key to on position or when i try to just start it up. i have to leave the key in the on position for about 4 minutes before i hear it come on then the jeep will start and it runs fine..no stalling or hesitation. i want to start by replacing the relay since its only 6 bucks but i lost to top to the fuse panel under the hood. can anyone tell me which one is the fuel pump relay?
littlefdl is offline
post #2 of 5 Old 02-25-2010, 11:54 AM
greasefingers
greasefingers's Avatar
1994 ZJ
Sounds like the classic leaking capacitors inside the PCM issue.
Cheers Steve
94 Black Laredo 4-Liter with QuadraTrac (42RE trans & NP249 TC) 200,000 + miles purchased new
88 Cherokee 2-door with 5speed manual 139K miles(deceased) purchased new
greasefingers is offline
post #3 of 5 Old 02-25-2010, 12:10 PM
JesseOR
Serious? There is the one that says, FUEL PUMP up to the left. That is the one he is looking for.
But yes it MAY be the ecu...
Try the relay first....
-Jesse-
GO DUCKS!
www.facebook.com/jesse.whitehargrove
JesseOR is offline
post #4 of 5 Old 02-25-2010, 12:32 PM
greasefingers
1994 ZJ
This picture is a couple years old and I took it because someone was looking for the fuel pump fuse. I should have stated that before. Yes the relay is clearly above it and to the left
It is almost never the relays. They are very dependable. Swap them around before purchasing.
Cheers Steve
post #5 of 5 Old 02-25-2010, 08:03 PM Thread Starter
littlefdl
1994 ZJ
Took the jeep to the shop today and i have an electrical short somewhere in the jeep. we tested the fuel pump relay slot with voltmeter and it would not keep a constant spark. tried to trace the short but could not find the source of the problem. after 215,000 miles im startng to think the PCM has bit the dust and is causing the problem.After 5 mins wit the key in ON position the fuel pump begins to run, jeep will crank and run fine. where can i find a PCM for a decent price?
Fuel pump relay trouble 99grandcheroki ZJ Grand Cherokee Forum 29 12-08-2009 05:16 AM
97 ZJ Fuel Pump Relay Issues redcountry ZJ Grand Cherokee Forum 1 07-25-2009 08:35 AM
No fuel pressure, Fuel Pump? CPS? ECU? Relay? 95cherokee33s ZJ Grand Cherokee Forum 2 10-22-2008 09:57 PM
Fuel pump or relay DRuta ZJ Grand Cherokee Forum 10 03-11-2008 10:51 AM
radiator relay and fuel pump relay nobleicon ZJ Grand Cherokee Forum 0 06-11-2002 02:18 PM
