Fuel pump issues, no power to pump? - JeepForum.com
post #1 of 71 Old 05-24-2013, 02:56 PM Thread Starter
Yttrium
Sorry I'm not searching around for this problem, I'm on my cell phone on the middle of no where with no Internet so this is my only way takes forever to load pages, anyway about a month of go my fuel pump went out I guess, my car wouldn't start no more said I was on empty with a full tank of gas, well I went out n bought all new hoses tanks straps fuel pump, everything. I finally get everything together n I go to start it n it says its empty on e not starting n I put 3 gallons in it. I checked all my fuses, connections everything is fine. I literally have no clue what could be the problem, I really need some help. My jeep is a 97 jeep grand cheroke 4.0 I6 thank you.
Yttrium is offline
post #2 of 71 Old 05-24-2013, 03:04 PM
Afdude88
Check the fuel pump relay and the asd relay. Switch em with the ac relay to test. Considering how your gauge aint working i would look at the connector at the pump. Look for recessed pins on both ends. I had the latter issue once....pita
1993 Grand Cherokee Limited 4.0L AW-4
1998 Grand Cherokee:
4.0L I6
42RE
242 tc
2.5 OME lift
Afdude88 is offline
post #3 of 71 Old 05-24-2013, 04:31 PM Thread Starter
Yttrium
Well i tired all that, still nothing thank you man for your time. Just wish I knew what exactly what is wrong.
Yttrium is offline
post #4 of 71 Old 05-24-2013, 04:54 PM
chetzar
1994 ZJ
I recently went through this ordeal with my dads Dodge Ram, it turned out to be a bad ground cable, you could try jumping the fuel pump with a battery to see if it kicks on.
chetzar is offline
post #5 of 71 Old 05-25-2013, 11:43 AM Thread Starter
Yttrium
Alright thanks bud, like the ground cables that are off the battery grounded everywhere under the hood? How would I jump the fuel pump with a battery?
Yttrium is offline
post #6 of 71 Old 05-25-2013, 02:59 PM
eagsc7
1994 ZJ
Have you tried beating the fuel tank? Also, when you drop the tank to replace the pump, It may not even be the pump... It could be a rodent chewed wire. I've had this happen with 2 jeeps, and even a friends van. Some rodents REALLY like the taste of whatever the factory uses to seal and protect some connections.
eagsc7 is offline
post #7 of 71 Old 05-25-2013, 03:18 PM
ZJNewbi3
I second re-checking the connector and jumping the pump. I replaced my fuel pump myself to fix a no-start problem and it wasn't even bad check for voltage at the pump connector too. (use a multimeter across the connector on the JEEP END) if no voltage it probably isnt the pump!
ZJNewbi3 is offline
post #8 of 71 Old 05-28-2013, 12:23 PM Thread Starter
Yttrium
Well alright, I'll try to do what I can. Thank you for the info on it all, most likely it's the wire idk how I'm gonna replace that or anything. Don't really have money to spend on mechanic, so ill post on here in a few days n see how far I get. Thank you everyone.
Yttrium is offline
post #9 of 71 Old 05-28-2013, 05:12 PM
eagsc7
1994 ZJ
Maybe try and just run a set of new wires to get it running. From the Junction box fuse 12(10a), run the wire to corospond with the Orange/Dark Blue wire to the fuel pump. If you have a LONG continuity tester, you can check the wire itself to see if the wire has gone bad. If it's good, then Check the connections(Should be 3) between the Junction Box and Fuel Pump. I'm looking at page 12-43 in the Haynes Repair Manual (50025).
eagsc7 is offline
post #10 of 71 Old 05-29-2013, 01:13 AM
Oldfrog
2007 WK
So you pulled the tank and installed a new pump inside it recently? Is there a possibility that something in the
tank or the connector outside the tank came loose?
As for the gauge, I know there was a recall on the fuel gauge sending units on the 97 model. ( which is the year I own, too) Did you have the dealership replace it?
How about an alarm system? Do you have one?
2007 5.7 Hemi, Ltd. QD II -
1997 ZJ, 4,0 select trac, Up country, track lok.
Oldfrog is offline
post #11 of 71 Old 05-29-2013, 05:51 PM
AaronButler
amongst trying the aforementioned ideas, check your fuel filter. Although I dont think it would be clogged that bad to where it wouldnt start, its worth a shot. They are pretty inexpensive, and if you dont remember when the last time it was changed.. its probably a good idea to do it now
1996 ZJ 4.0 Laredo... you know, the one with the ripped leather seats
AaronButler is offline
post #12 of 71 Old 05-29-2013, 08:35 PM
KoreaZJ
1994 ZJ
See diagram below...
  1. Remove Fuel Pump Relay
  2. Test relay socket Pin#16, should have +12v always. If no voltage, check PDC Fuse#16 (20amp)
  3. Test relay socket Pin#18, should have +12v with Key ON. If no voltage, check PDC Fuse#18 (15amp)
If above tests are good, briefly short relay socket Pin#16 to Pin#17... fuel pump should run. (even with Key OFF)
If not, perhaps bad pump, wiring, or connections.
Fuel gauge level sensor is a variable resistor. PCM supplies both PWR/GND.
KoreaZJ is offline
post #13 of 71 Old 05-30-2013, 11:39 AM Thread Starter
Yttrium
Yes I install the pump a few weeks ago, I've check the volts n everything, for the relay fuse box, there's power but somewhere past it the wires are shot. I checked the plug by the fuel pump the female one n there's not even power coming from there, or the wires behind it. So somewhere, the wires have gone bad I guess, I'm about fed up with it. Today I almost to a sledge hammer to the jeep. I even hooked a wire up to the relay n ran it to the new pump n still no power. I'm about to take it to a shop because I'm completely lost with everything. Thnk you everyone for your help I wish this was something easy.
Yttrium is offline
post #14 of 71 Old 05-30-2013, 09:00 PM
ZJNewbi3
Make sure you check all grounds and look by exhaust components for melted wires and check the whole engine bay for any damaged wires! I was in the same spot you were a few months ago just be patient!
Just trying to keep her goin'!!
ZJNewbi3 is offline
post #15 of 71 Old 05-30-2013, 09:41 PM Thread Starter
Yttrium
I know I'm trying to be, just so stressful. I ended up kicking my door forward n bending it because I was so angry earlier haha anyway what was your problem zjnewbie?
Yttrium is offline
