Fuel Pump - JeepForum.com
post #1 of 3 Old 06-30-2003, 02:17 PM Thread Starter
Hammerhead
Fuel Pump
I think my fuel pump is dead. Has anyone had one replaced lately?
Hammerhead is offline
post #2 of 3 Old 07-31-2003, 06:47 PM
Swamp Boy
Swamp Boy's Avatar
Do a search for fuel pumps and find the thread I started..
Good luck..
Just another soccer moms Grocery getter....
Swamp Boy is offline
post #3 of 3 Old 07-31-2003, 07:44 PM
PDshooter
Did you Ck your Fuse first?
One trick is to spray carb, cleaner as the engine is turning over. If it try to start, then it's a fuel problem.
I had a fuel injector go bad once. No resistance. When I found the bad one I pulled the wires off it. The car started and ran on 5 cyl.Like $h#t.of course, but it ran.
96 GC 117K 4.0
Sele-Trac
Retired guard 20yrs
MOS 63H 11B 43E
PDshooter is offline
New aftermarket high quality fuel pump? second pump in 3 years?!!!!? SPL Tech ZJ Grand Cherokee Forum 8 11-02-2010 05:12 PM
Fuel Pump & Fuel Lines - Connections jeremiahgreer ZJ Grand Cherokee Forum 5 02-02-2010 04:19 PM
No fuel pressure, Fuel Pump? CPS? ECU? Relay? 95cherokee33s ZJ Grand Cherokee Forum 2 10-22-2008 08:57 PM
Fuel Pump/Fuel Tank Problem ma-usa1 ZJ Grand Cherokee Forum 18 04-09-2008 07:28 PM
Fuel Pump/Fuel Tank Problem ma-usa1 ZJ Grand Cherokee Forum 0 02-05-2003 06:02 PM
