Fuel pressure and vacuum question - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Fuel pressure and vacuum question
Black Friday- Cyber Monday Deals at jeepHutBlack Friday Deals !JcrOffroad Black Friday Sale!
Unread 06-27-2014, 08:55 PM   #1
93zjer
How much should my fuel pressure and vacuum fluctuate when the jeep is running?
My fuel pressure fluctuates rapidly between 34 and 39 psi at idle.
When I unplug the vacuum line from the regulator the pressure goes to a very stable 39 psi.
My manifold vacuum also rapidly fluctuates between 17 and 20 inHg.
93zjer is offline   Reply With Quote Quick reply to this message
Unread 06-27-2014, 08:57 PM   #2
93zjer
Yes I bled the gauge.
Unread 06-27-2014, 09:27 PM   #3
ZeeJay1997
sounds like you've got something going on with the valves. try some top end cleaner.
ZeeJay1997 is offline   Reply With Quote Quick reply to this message
Unread 06-27-2014, 10:38 PM   #4
93zjer
I just noticed that my fuel pressure instantly drops to zero when I turn off the engine.
I clamped off the return line to see if it the check valve in the fuel pump or the a leaking injector.
Pressure rose to exactly 70 psi before shutting off engine. After 30 minutes it fell to by 19 psi to 51 psi.
Unread 09-20-2014, 01:34 PM   #5
93zjer
It was the check valve in the fuel pump for the return line.
Unread 09-20-2014, 07:49 PM   #6
mikem350
1994 ZJ
I bought a universal check valve (for gasoline) 3/8 line size off ebay...might work if you don't want to swap the pump
Proud owner of TWO 4.0 Laredos
Red 94 w/133k, mint!
Silver 98 w/249k runs as new!
mikem350 is offline   Reply With Quote Quick reply to this message
Unread 09-21-2014, 01:43 PM   #7
93zjer
Interesting idea. I actually already replaced it, it was lifetime warranty.
I tried in the past to do the swampboy external pump mod but I got a new defective pump (MSD brand via summit). I waited almost a year before I went to install it and found it was defective so now I have a MSD paper weight.
