Fuel pressure test port sprays air - JeepForum.com
post #1 of 5 Old 07-22-2011, 02:22 PM Thread Starter
misterdude89
97 Jeep Grand Cherokee with 4.0L. I have been having problems with intermittent sputtering and stalling under load. To check for fuel pressure I pressed in the shrader(test port on fuel rail) valve and noticed a spray of fuel and air rather than a solid stream of fuel. Is this common? Also, no codes have occured which is odd and makes diagnosing the problem VERY difficult.
misterdude89 is offline
post #2 of 5 Old 07-22-2011, 10:52 PM
classicmetalman
Did you check the pressure with a gauge? There will be a quick shot of fuel if you just press the valve, but not a constant flow. As far as the air, not sure. Don't remember if your '97 has an inline filter or not, but if it does, when was the last time you changed it? Post up your pressure readings. BTW, leave the gauge hooked up and shut down the Jeep. Wait a while and make note of pressure drop, shouldn't be significant.
HTH
Robert
93 Laredo 4.0
96 Limited 4.0
Originally Posted by murphydajeep View Post
I say you should still hit something just to let it know you mean business, or shake a hammer at it in a menacing fashion
classicmetalman is offline
post #3 of 5 Old 07-22-2011, 11:54 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
97 doesn't have an inline filter.
you need a gauge, just hitting the valve core doesn't tell you much other than there is gas there.
ratmonkey is offline
post #4 of 5 Old 07-23-2011, 04:59 PM Thread Starter
misterdude89
I have measured with a gauge and read 45psi with engine running. Fuel filter is part of the fuel tank module and was changed with fuel pump. And pressure is maintaned for awhile after shutting off engine.
post #5 of 5 Old 07-23-2011, 09:42 PM
TheHalfWit
What brand of fuel pump was used as the replacement? Personally I doubt that its the fuel filter, I recently discovered that my fuel filter was likely more then 10 years old after I ended up cutting it out of the bracket and the only symptoms I had was that I had to shove the pedal harder to accelerate, and mileage sucked. 45 Psi sounds a bit high though, but they might have changed the specs between the 4.0 and the 5.2, or 93-95 and 96-98.
Calm. C.
If a week goes by without needing to replace something, pinch me because I must be dreaming.
TheHalfWit is offline
4.0l , fuel , pressure test , stalling
fuel pressure test. coralman ZJ Grand Cherokee Forum 6 11-02-2010 01:07 PM
What are symptoms of faulty fuel pressure regulator/fuel pump Tehnation ZJ Grand Cherokee Forum 4 09-13-2010 11:39 AM
AC leak at high side test port zj95 ZJ Grand Cherokee Forum 5 04-20-2009 12:15 AM
Did a coolant pressure test and....nothing... jpl ZJ Grand Cherokee Forum 10 03-05-2009 11:13 PM
Fuel pressure test? flybop ZJ Grand Cherokee Forum 2 02-25-2009 09:51 AM
