Fuel pressure gauge adapter - JeepForum.com
post #1 of 14 Old 08-24-2013, 01:21 PM Thread Starter
Billyjoebob007
I bought this pressure gauge:
http://www.amazon.com/OTC-5630-Fuel-...words=OTC+5630
And didnt realize i dont have the port on the fuel rail on me ZJ
I need adapter "Miller 6923", so i can do fuel pressure check:
http://www.costplustools.com/Miller-...ST_p_9066.html
$120 !!! Is there a cheeper adapter i can connect to the pressure adapter i bought ?
Billyjoebob007 is offline
post #2 of 14 Old 08-24-2013, 02:24 PM
Oldfrog
2007 WK
I dont remember having to buy anything for my fuel gauge in order to hook it up. It's not here right now, or I'd take a pic of it for you.
2007 5.7 Hemi, Ltd. QD II -
1997 ZJ, 4,0 select trac, Up country, track lok.
Oldfrog is offline
post #3 of 14 Old 08-24-2013, 03:24 PM
Kingr98
2016 JK Wrangler
I'm not sure about your 5.2L, but I got this pressure gauge from Harbor Freight.
http://www.harborfreight.com/fuel-in...ter-92699.html
It looks like it has the "T" connection that you need to put the gauge inline between the fuel line and the rail. It is not a high quality tool, but it did get the job done for around $20.
Kingr98 is offline
post #4 of 14 Old 08-24-2013, 04:57 PM
coralman
USER OF PARTS CATALOGS
coralman's Avatar
I dont think I've ever seen one without the port except wj's. I know if you order a new fuel rail now you get the same rail as the wj with no port.
Originally Posted by HighLonesome
coralman is online now
post #5 of 14 Old 08-24-2013, 08:47 PM
jabba974
There should be some type of valve on the fuel rail...don't know that I have ever seen one without it...
jabba974 is offline
post #6 of 14 Old 08-24-2013, 08:50 PM
Kingr98
2016 JK Wrangler
I have never seen a ZJ without a port either, but The FSM actually says that depending on the vehicle model and engine that 5.2L engines may or may not have a test port. I guess I learn stuff every day.
Kingr98 is offline
post #7 of 14 Old 08-24-2013, 09:01 PM
jabba974
Time to swap it out for some "hi-flow" fuel rails! BIG HP! and a test port....LOL
jabba974 is offline
post #8 of 14 Old 08-25-2013, 12:15 AM Thread Starter
Billyjoebob007
Yep, no test port on mine = Suck
In the service manual it calls for test with or without test port, fuel system/Sec 14-8 - 14-9 . Hence why i need that miller 6923 adapter
Looking for something cheaper i can connect to the fuel rail quick disconnect fuel line and to that gauge i bought.
post #9 of 14 Old 08-25-2013, 12:23 AM Thread Starter
Billyjoebob007
Im guessing that long silver piece is what i may need but the question is, is that particular piece pictured the right size to fit my jeeps quick disconnect ? There are a bunch of different sizes. Looks like that one is : " 1/4 in. & 3/8 in. barbed T-fitting" ? one end is 1/4 and the other end 3/8 ? I guess i may buy that kit and roll the dice and burn another $20 + shipping on that one.
post #10 of 14 Old 08-25-2013, 12:38 AM Thread Starter
Billyjoebob007
I find no such thing anywheres.
post #11 of 14 Old 08-25-2013, 01:45 AM
jabba974
Since you got an OTC tester, I am almost certain they would have the adapter to go in the fuel line...and I doubt that it would cost you $100 bucks...Worse case, build your own from repair fittings...
jabba974 is offline
post #12 of 14 Old 08-25-2013, 06:45 AM
Kingr98
2016 JK Wrangler
There are three Harbor Freight stores in Denver. Go have a look at one before you buy it and see if you think it will work first. My local store had a whole stack of them on the shelf.
Kingr98 is offline
post #13 of 14 Old 08-29-2013, 12:03 PM Thread Starter
Billyjoebob007
Went to junkyard yesterday and snagged a fuel rail with the port, issue solved.
post #14 of 14 Old 08-29-2013, 02:47 PM
JeepNicholson
Haha you should add that to the "you know you drive a zj when..." thread
"When you buy parts for your Jeep to fit your tools and not the other way round"
JeepNicholson is offline
