fuel pressure - JeepForum.com
post #1 of 5 Old 02-02-2013, 10:47 AM Thread Starter
richh789
1987 YJ Wrangler
fuel pressure
With the key in the on position, when I press Schrader valve, fuel comes out, but stops.
My question is, should fuel pump keep pressure up, or does it need yo be running to maintain pressure?
richh789 is offline
post #2 of 5 Old 02-02-2013, 11:19 AM
GotMoose
1994 ZJ
The fuel pump is controlled by the computer. It runs: a few seconds when the key is turned on, at cranking and when the engine is running. The computer turns it off the the engine is not running.
GotMoose is offline
post #3 of 5 Old 02-02-2013, 04:12 PM Thread Starter
richh789
1987 YJ Wrangler
I wasn't sure. Having no start prob with spark. I figured to fuel.
After comp test I learned the pass side bank is completely flooding. About a teaspoon full in tester each cylinder
richh789 is offline
post #4 of 5 Old 12-01-2013, 05:42 AM Thread Starter
richh789
1987 YJ Wrangler
Ended up being a bad socket for ecm relay
richh789 is offline
post #5 of 5 Old 12-01-2013, 07:55 AM
coralman
USER OF PARTS CATALOGS
coralman's Avatar
The fuel pump relay or the main plug to the pcm? Just asking.
Originally Posted by HighLonesome
coralman is offline
