Fuel light - JeepForum.com
post #1 of 23 Old 08-19-2013, 12:06 AM Thread Starter
Syncityj
Hey guys. I just have a random question.
I filled the ZJ up today after the fuel light came on. My mini overhead console said I had about 20 miles till empty. I filled to until it clicked and that was at 18.4 gallons. Now I have the build sheet from Chrysler which says 23 gallon tank. Correct me if I am wrong but that doesn't seem right, 4.5 gallons for 20 miles? Can anyone shed some light on this for me?
I also use a scangauge 2 and that showed I was at 18 or so gallons used. So, why would my fuel light come on so soon and my dte show an incorrect mileage? My scangauge seems much more accurate then computer in the car, even though its plunged into the obd2 port.
Any advice helps.
Side note, my mini console doesn't reflect any accurate information for an unknown reason. I did however think that the dte would be pretty close.
Syncityj is offline
post #2 of 23 Old 08-19-2013, 12:21 AM
dnuccio
i would be very surprised if the fuel gauge and the DTE read accurate. on mine, i can run the gauge down below the E and it will still go for a little bit.
Reliability is relative
R.I.P. Ratmonkey
dnuccio is offline
post #3 of 23 Old 08-19-2013, 12:21 AM
phitmein
phitmein's Avatar
I don't know if it has anything to do with it, but I have read that it is not good to run out or get to low on fuel because it can trash the fuel pump because it is cooled by the fuel or something .
Just a thought .
phitmein is offline
post #4 of 23 Old 08-19-2013, 12:27 AM Thread Starter
Syncityj
Just a thought .
I usually never let it get that low. I have heard its bad for the injectors too. Never seen any actual proof if either claim.
Syncityj is offline
post #5 of 23 Old 08-19-2013, 12:28 AM
David97
To prevent you from running out of gas. Ive ran mine for about 40miles after my dte said zero before. I use it as a guide, but don't really use it as a for sure thing. Just to get an idea.
Just a fail safe, dumby proof type thing to prevent you from running completely out of gas.
David97 is offline
post #6 of 23 Old 08-19-2013, 12:33 AM Thread Starter
Syncityj
I can see that...I mean, I assumed that the 4.5 gallons was a reserve. Like I said I am not a fan of having the fuel light come on, but money gets tight every now and again.
Syncityj is offline
post #7 of 23 Old 08-19-2013, 12:42 AM
xcaliber81
I have a 2008 dodge caliber and am the original owner and since it was new i have always ran it till almost empty since day one and have yet to see any adverse affects and it has 137000 kms.
xcaliber81 is offline
post #8 of 23 Old 08-19-2013, 12:53 AM
coltman151
The most I've ever been able to pump into mine was 20 gal, and that was needle pegged on e. I love that feature of making me think I'm low. I'm a college kid and its nice to know I've still got enough to get me to town if something happens and I'm broke.
On a side note, I ran my chevy out of gas once. A week later, a new fuel pump was required. So ill never run my zj on its reserve unless its an emergency. May not be related but I'm not chancing it.
95 Laredo 4.0, 2" RE BB, RC N2.0 Shocks, Custom Roof-Mount Light Bar w/ 6 lights, Bumpers deleted, Homemade sway bar discos, Michelin LTX 31x10.50s, and a Dog Box :)
Planned: Homemade Spare tire carrier, double shear front track bar, 4 adjustable rear control arms, New Rims and 33" Wrangler MT/Rs or BFG M/T KO's w/ LOTS of trimming.
coltman151 is offline
post #9 of 23 Old 08-19-2013, 10:07 AM
V65Ozzie
Mine always comes on with the exact same amount of gas left, and it's always a mile short of the nearest gas station.........
V65Ozzie is offline
post #10 of 23 Old 08-19-2013, 11:40 PM
David97
Lol 130 miles on 3/4ths a tank of premium?
David97 is offline
post #11 of 23 Old 08-19-2013, 11:49 PM
xcaliber81
when I had a 1/2 tank it said i had 290 kms till empty but i just recently put mine in though is there a way to calibtate it? are v-8 and 4.0 gas tanks the same size?
post #12 of 23 Old 08-20-2013, 04:24 AM
Uniblurb
Uniblurb's Avatar
Believe the fuel tanks are the same size for both the 4.0 & V-8's since the parts list goes by year/body style rather than engine size. On my 96 4.0 the gal size isn't given for the tank (#52100058, Fed), nor is it on my build sheet, but think it's 20.2 gals. May be the same for the 94-95 ZJ fuel tanks (#52127523, Fed)?
96 4.0 ZJ Laredo, 2004 4.7L WJ Limited, 93 4.0 XJ (spare), 96 4.0 XJ (son's)
Uniblurb is offline
post #13 of 23 Old 08-20-2013, 05:26 AM
txbass06
The only time I've ever ran mine out of gas was a few days ago. Gauge showed a hair under 1/8, dte was at 31 and my fuel light never came on. Thinking that was a fluke though since I've ran it down lower than that and had the fuel light come on while I was heading to fill up
txbass06 is offline
post #14 of 23 Old 08-20-2013, 05:46 AM
ZeeJay1997
before i changed the fuel pump in mine i ran it until DTE was at 0. when i pulled the tank and emptied it into a can, there was about 4 gallons.
ZeeJay1997 is offline
post #15 of 23 Old 08-20-2013, 08:36 AM
Kingr98
ZeeJay,
After you changed the pump, is it more accurate? Or does is still have a lot of fuel left in the tank when DTE = 0?
Kingr98 is offline
