Fuel leak - Page 2 - JeepForum.com
post #16 of 29 Old 01-05-2013, 11:43 PM Thread Starter
xcaliber81
I actually don't know i could not get mine done because i think it only relates to factory installed rotors.
xcaliber81 is online now
post #17 of 29 Old 01-05-2013, 11:45 PM Thread Starter
xcaliber81
I actually don't know they told me it only relates to factory installed rotors so i couldn't get it done.
post #18 of 29 Old 01-07-2013, 11:53 AM Thread Starter
xcaliber81
So I ordered it up today 28.00$ before tax at mopar I'm going with a dodge one assuming the one on there now is factory if its lasted that long 28$ is a small price to pay. So I deffinetly have to drop my tank right there's no access on the floor?
post #19 of 29 Old 01-07-2013, 06:15 PM
Okie_Rider
1994 ZJ
Got to drop her. I used a floor jack to lower and raise
"JEEPING... Because football, baseball, basketball, and soccer only require one ball."
'94 JEEP ZJ A.K.A "THE TANK"
Okie_Rider is offline
post #20 of 29 Old 01-07-2013, 06:22 PM
newfieZJ
Tank has to come out , no other way around it IMO unless you wanna hack up the floor . Not too sure you wanna do that with a leak
Get the tank as empty as possible . Makes it easy to work with . I ran mine to below empty , left maybe an inch in the tank .
Start by soaking everything with PB Blaster and depressurizing the system . Remove the gas cap to vent the tank , release the pressure from the fuel rail .
Then let the gas fill and vent hoses go . This can be a little tough , they bond to the filler pretty good . Use a short flat top screwdriver , get your arm way up there and push the screwdriver tip downwards between the hose and filler . Do it it in a few spots , it should wiggle off no problem once the seal has broken .
Now disconnect the plug in , let the fuel supply line go , then the vent line
Not sure if you have the skid , I didn't . It will also have to come off . It's recommended the exhaust heat shield be removed , meh , I didn't but I did see where it would make more room . Hit the 2 bolts with WD-40 just before you take them off (after a presoak) . I hit mine with the impact . If you do this , clamp the upper side of the bolt with vice grips to stop it from rattling about Obviously , you need something to hold the tank up . A floor jack works great . Once the straps are let go , start letting the tank down . The pass. side will drop while the other side is held up wuth the 2 hoses . Start feeding those through the frame as the tank is lowered . I did mine without lifting the jeep up to this point but raising the pass side at this point helped get the tank out the rest of the way . That exhaust heat shield ....may... have helped . By now , the tank is on the floor .
Now your gonna see this , ewww
To remove this dirt , a small pointed screwdriver and a shop vac work great
Disconnect any remaining lines from the pump and vent . Now the get the lock nut off . I know I didn't have a "special tool" , and it's not coming off by hand at any point of removal . My solution was use a large flat top , but blunt chisel . 2-3 medium taps per tab and work your way around . Don't use the top , use the side of the tabs . It will start to move slowly , then get better . Don't try to turn it all the way off one tab , it will just break .
Pull up on the pump and remove it , note it's position . Remove and simply replace the seal . That's an easy thing to do .
newfieZJ is offline
post #21 of 29 Old 01-07-2013, 09:31 PM Thread Starter
xcaliber81
Wow thanks I am sure that will come in handy.
post #22 of 29 Old 01-08-2013, 10:36 PM Thread Starter
xcaliber81
just wondering why is it important to put the pump back the way it came out?
post #23 of 29 Old 01-09-2013, 04:09 AM
newfieZJ
fuel supply line has to face forwards , but, the filter does spin . the float was 90*of that on the pass side . maybe it would not matter , I like things to go back as the were
newfieZJ is offline
post #24 of 29 Old 01-11-2013, 10:39 AM Thread Starter
xcaliber81
Also if im dropping my fuel tank should i replace my filter or is it replaceable?
post #25 of 29 Old 01-13-2013, 12:08 PM
newfieZJ
There is a pick up screen on te bottom you could/should replace , it just pushes/pops on . The filter on the top I can't seem to get off , maybe a special tool or technique required . I didn't wanna bust it up .
newfieZJ is offline
post #26 of 29 Old 01-13-2013, 12:25 PM Thread Starter
xcaliber81
I asked already and the filter is non replaceable ill have to look into the pickup screen thanks again.
post #27 of 29 Old 01-24-2013, 10:26 AM Thread Starter
xcaliber81
I should have asked this before but how do I release the pressure from the fuel rail? I am going to do this today, never mind I figured it out.
post #28 of 29 Old 01-24-2013, 05:56 PM Thread Starter
xcaliber81
WOW its a good thing i did this my fuel pump was not installed correctly, the really thick seal was only placed on the first ridge so it stuck up 1/4 inch more than it should. No wonder it leaked.
The good news is no more leak. Ill tell you what though it fought me the whole time trying to get that stupid tank. Now that i know how its done next time will be much easier for sure.
Oh ya before It was pointed out to me I guess there is a vent on the fuel rail i think, I just yanked the fuel lines off the rail WOOPS lol.
post #29 of 29 Old 02-02-2013, 11:39 AM Thread Starter
xcaliber81
My fuel mileage seems way better atm I am at an 1/8th less that 3/4 and I have driven about 215ish ins
