Fuel leak - JeepForum.com
post #1 of 1 Old 08-19-2011, 07:23 PM Thread Starter
ccoston
Fuel leak
I took my Jeep for it's first longer range trip last week, camping up in Sequoia National Park. I was nervous, as I've done a LOT of work just to get it to this point and I was afraid of something going wrong with the family in the Jeep somewhere way up in the mountains.
Everything went great, with the exception of this problem:
When filling up with gas, if I don't stop the tank at 7/8 full, gas will start pouring out from the ring that holds the fuel pump assembly in place. It drops a LOT, with one instance about a gallon coming out and bystanders looking below my Jeep. I was pretty embarrassed. I felt around and it feels like the only wet area is around the ring, not on top of the pump or from any other area, so I think it's flowing out from under the ring. I made sure last time I had the tank down that I tightened very tight, using a rubber mallet and a piece of 2x4 to get traction on the ribs on the white plastic to make it tighter. Definitely a lot tighter than hand tightened.
I recently changed the fuel pump and used a new gasket. I didn't use gasket sealer or anything, should I have? I just put the new rubber in place and slid the fuel pump assembly into that.
ccoston is offline
Fuel Leak on '94 JGC wcf591 ZJ Grand Cherokee Forum 2 01-13-2011 02:59 AM
Help fuel leak on fuel rail 2002 4.0 jzhawk ZJ Grand Cherokee Forum 2 11-17-2009 12:56 PM
Fuel Leak QM2Rick ZJ Grand Cherokee Forum 3 08-05-2008 05:13 PM
fuel leak mat1 ZJ Grand Cherokee Forum 1 04-18-2006 06:38 AM
Fuel leak? HarleyTyson ZJ Grand Cherokee Forum 3 01-09-2006 07:40 PM
