Fuel injectors 5.9 upgrade, to 4 hole injectors - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Fuel injectors 5.9 upgrade, to 4 hole injectors
NOTCH CUSTOMS - Max Clearance Fender FlaresIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineROCKRIDGE 4WD Supports our Service Members! Military Disc
Unread 06-27-2011, 10:45 AM   #1
divco13
Has any of you swaped single port, to 4 port ( hole ) Injector's on your 1998- 5.9.
What Make, and Model / Year
Want to keep rate of flow the same, just better atomization.
Looked for a conversion chart on line, no luck
Bob
divco13@aol.com
http://oldcarandtruckpictures.com/Divco/BobPatterson/
http://www.facebook.com/pages/Divco-Milk-Truck/102362503162366
divco13 is offline   Reply With Quote
Unread 06-27-2011, 10:56 AM   #2
zander21510
Mr. Fix-It.
zander21510's Avatar
I've done it on my 4.0...i've read from most places for the 4.0 and 5.2 the flow rate is the same, if its the same for the 5.9 then it should work. I pulled mine from 95-97 Cirrus. Look at your local JY for chrysler cars with 2.0 engines, the injectors have 2 numbers, one ends in 703. Its so easy I took the things out in about 10 minutes, installed in my jeep in about 20 minutes. Well worth it, idles smoother and better throttle response.
1995 Jeep Grand Cherokee; 199,000 miles (5/12/13)
198k: 3/17/13; 197k: 2/22/13; 196k: 12/20/12; 195k: 10/26/12; 194k: 8/17/12; 193k: 5/29/12; 192k: 3/16/12; 191k: 2/18/12; 190k: 12/31/11
Current mods: 703 injectors(my howto), intake modification, 99+ intake manifold (my howto), Magnaflow hi-flow cat from Kolak & Cherry Bomb glasspack.
zander21510 is offline   Reply With Quote
Unread 06-27-2011, 11:13 AM   #3
melk
#703 from mid-90s 2.4L Chryslers
#715 from mid-90s 4.6 & 5.0L Fords
Well worth the couple bucks to get new filter baskets IMHO
melk is offline   Reply With Quote
Unread 06-27-2011, 02:17 PM   #4
Grand_ZJ
Good info.
1998 ZJ: 5.2L, 2" lift, 33/12.50/15 Dakota A/T2's, 231J swap, D30;D44A, Sliders, rear plate bumper.
Grand_ZJ is online now   Reply With Quote
Unread 06-27-2011, 02:41 PM   #5
Scottso699
Scottso699's Avatar
2006 WK
I switched to Ford Racing 24lbs 4 port injectors on my 5.9L. I saw a boost in fuel economy. I imagine due to it being a better flowing injector.
Scott
2006 WK Overland - K&N CAI, Superchips Programmer, Dynomax Ultra Flo Muffler, 180 Degree Thermostat, 255/75r17 BF Goodrich M/T Tires, 1.25" Wheel Spacers, Resonator Delete, OME HD Lift
1998 ZJ 5.9L Limited - SOLD - Pictures
Scottso699 is offline   Reply With Quote
Unread 06-27-2011, 04:15 PM   #6
zander21510
Mr. Fix-It.
I remember reading about the flow rate for the 703's, supposedly they are rated lower than they actually flow...a few bench tests proved that they flow at the same rate as the stock injectors.
Unread 06-27-2011, 05:08 PM   #7
CatSplat
Derp.
CatSplat's Avatar
1994 ZJ
My 5.9 runs great on the 703's, your '98 should have no problems, especially with the higher fuel rail pressure. Change the internal filters, as mentioned (and pictured) above.
1994 5.9L ZJ, retrofitted UC package, NP242 swap, 17" JK Moabs with 32" BFG MT KM's.
Junkyard Jeeper
CatSplat is offline   Reply With Quote
Unread 06-27-2011, 07:21 PM   #8
MaintMech
MaintMech's Avatar
http://www.bonanza.com/booths/Turbop...TLE_CAPS___EV3
Rebuild kits. Another member provided this link. I'll be using it soon.
It moans and groans, whines and whirrs, sputters and sparks.
It gets me there and back, it's my JEEP!!
MaintMech is offline   Reply With Quote
Unread 06-28-2011, 09:22 AM   #9
divco13
  1. Just found this chart, on all fuel injector by Bosch.
  2. http://www.justfuelinjectors.com/ser...CHRYSLER_MOPAR
  3. Chrysler - Mopar Section, Look far right for application
  4. Is the Impedance, High or Low ?
Bob
divco13@aol.com
Unread 06-28-2011, 09:25 AM   #10
divco13
Where are this on a 5.9 fuel rail ?
Bob
divco13@aol.com
Unread 06-28-2011, 09:58 AM   #11
CatSplat
Derp.
CatSplat's Avatar
1994 ZJ
The injector filters are inside the top of the injectors themselves. They can be removed with an appropriately-sized (#10 usually works) metal screw and a pair of pliers.
This is the guide I followed the first time I did injectors; it is for older EV1 injectors with an external (and easily damaged) pintle, the 703s do not have that and thus are far less easy to damage:
http://www.rowand.net/Shop/Tech/DIYFuelInjectorCleaning.htm
The basics of replacing seals and filters is identical to the EV3s.
Junkyard Jeeper
Unread 06-28-2011, 03:22 PM   #12
divco13
When we get done here we will have a nice data base, for All
There for, What is the full part # for the so called Bosch 703's
Bob
divco13@aol.com
Unread 06-28-2011, 04:56 PM   #13
CatSplat
Derp.
CatSplat's Avatar
1994 ZJ
Part number 0-280-155-703.
http://www.jeepforum.com/forum/f13/d...4-0-a-1145336/
Junkyard Jeeper
Unread 06-28-2011, 05:50 PM   #14
divco13
[B][B]
Stock 98 injectors out of a 2.4 are 0-280-155-782 Bosch Injectors, part number 04669772.
21.3 lb/hr @ 43.5 psi.
Stock 96 injectors out of a 2.4 are 0-280-155-703 Bosch Injectors, part number 05277739AB.
16.75 lb/hr @ 43.5 psi.
Stock 97 injectors out of a 2.4 are 0-280-155-740 Bosch Injectors, part number 4669471AB.
21.1 lb/hr @ 43.5 psi
0-280-155-703 - - - Chrysler 4-2.4l, Dodge 4-2.0l
Bob
divco13@aol.com
Unread 06-28-2011, 07:49 PM   #15
jforse
Sleeping
jforse's Avatar
Are these what they call EV6 blue tops?
jforse is offline   Reply With Quote
