Fuel injector cleaner - JeepForum.com
Closed Thread
post #1 of 21 Old 03-17-2008, 01:28 PM Thread Starter
WhiteOut
WhiteOut's Avatar
I just picked up a bottle of STP Fuel Injector Cleaner form Canadian Tire, it says to add the whole thing to a full tank of gas. Is there anyreason why I should not use it? Bad for the Jeep?
WhiteOut is offline
post #2 of 21 Old 03-17-2008, 01:30 PM
Dillonzj
as long as you have a full tank of gas I dont think its going to hurt.. On my 94 I had an injector that would clog sometimes and make the jeep miss out.. but after I used that stuff I never had the problem again
-Dillon
98' JEEP GRAND CHEROKEE LIMITED 5.9
149k 5.9L v8 White
Crane Cam shaft and Crane, Roller Rockers, bored .030 over, edelbrock performer heads, M1 Intake manifold, Fasstman throttle body, magnacore wires, platinum plugs, K&N FIPK, dough thorley headers,3" high flow cat, 3" magnaflow mandrel bent exhaust, SCT tuned
***future mods -5.5 IRO LA - KOR sliders -KOR roof rack -
SOLD-
95' JEEP GRAND CHEROKEE LIMITED
188k 5.2L v8 White 98 ZJ rims
Originally Posted by nashmd454 View Post
...we all know they empty our pockets...yet they fill our hearts...
Dillonzj is offline
post #3 of 21 Old 03-17-2008, 01:32 PM Thread Starter
WhiteOut
WhiteOut's Avatar
Sweet, the tank is just over 3/4 full right now so Ill add it before I go out today.
WhiteOut is offline
post #4 of 21 Old 03-17-2008, 01:36 PM
Dillonzj
yeah that should be fine... I think thats where mine was.. there big tanks but I wonder why it says you should have a full tank
-Dillon
149k 5.9L v8 White
SOLD-
Dillonzj is offline
post #5 of 21 Old 03-17-2008, 01:51 PM
aeropatr82
If your injectors are dirty that stuff is like putting a bandaid on it. Check out www.premiuminjectorservices.com This is the real way to clean injectors.
aeropatr82 is offline
post #6 of 21 Old 03-17-2008, 01:54 PM
Dillonzj
well I dont have the 94 anymore the 84 lumber car took it away from me.. kinda
but thanks for the link Is lucas any good?
149k 5.9L v8 White
SOLD-
Dillonzj is offline
post #7 of 21 Old 03-17-2008, 03:27 PM
_Kyle_
_Kyle_'s Avatar
My friend is convinced that Techron fuel injector cleaner is amazing. I might have to check it out sometime. I just threw in some Mopar CCC last week.
-Kyle
1996 Grand Cherokee
2005 Wrangler Rocky Mountain Edition
RIP Troy (bigbluezj94)
_Kyle_ is offline
post #8 of 21 Old 03-17-2008, 03:29 PM
itasor
itasor's Avatar
2009 JK Wrangler
I used the STP Fuel System Cleaner and it worked nice. It doesn't seem to hesitate on steep hills in overdrive as much anymore.
Isn't Mopar CCC an aerosol spray? Or do they have a liquid you can put in the gas tank? If so, do you have the part #?
itasor is offline
post #9 of 21 Old 03-17-2008, 03:46 PM
_Kyle_
_Kyle_'s Avatar
It's an aerosol. It seemed to help a little bit. I figure since my manifold crapped out I might as well go down the line and take care of stuff to get my mileage up.
-Kyle
1996 Grand Cherokee
_Kyle_ is offline
post #10 of 21 Old 03-17-2008, 03:55 PM
UTChavok
I use the Lucas fuel treatment, that stuff works great. Also have used thier oil stablizer and transmission fix.
http://www.lucasoil.com/products/dis...tid=2&loc=show
-Ronnie
UTChavok is offline
post #11 of 21 Old 03-17-2008, 05:37 PM
superj
the reason it says to use the whole tank is because the regular sized bottles are for tanks under a certain size. they have a larger bottle for larger tanks. you can run your tank down to about 1/2 and then fill it up with alcohol to clean out anything also. will make it really easy to pass an exhaust gas analyzer for a safety inspection also. alot of bmw guys with modified motors do it in cali so they can pass emissions inspections
I don't feel like working on anything at this time so i sold my yj.
superj is offline
post #12 of 21 Old 03-17-2008, 06:02 PM
Intense-Dakota
I use STP about 3-4 months in all of my vehicles and have for years. Its best to start early instead of waiting untill there is a problem. Remember its a cleaner...... not a fixer.
Intense-Dakota is offline
post #13 of 21 Old 03-17-2008, 06:27 PM
superj
good point on that last part
superj is offline
post #14 of 21 Old 03-17-2008, 06:33 PM
greasefingers
greasefingers's Avatar
1994 ZJ
I donít ever put any additives in my gas tank. I donít believe it hurts or helps. Injectors are one of the most reliable actuators on any vehicle. Leaking O-rings can be common on vehicles with over 175,000miles. Then the next thing to fail would be the solenoid. These issues usually come before clogging is a problem.
Cheers Steve
94 Black Laredo 4-Liter with QuadraTrac (42RE trans & NP249 TC) 200,000 + miles purchased new
88 Cherokee 2-door with 5speed manual 139K miles(deceased) purchased new
greasefingers is offline
post #15 of 21 Old 03-17-2008, 06:55 PM
superj
maybe the fuel filter is partially clogged and causing a slight hesitation? if you are pretty bored, with how easy these injectors are to get to, you could just pop them out and spray them down with carb cleaner.
superj is offline
Closed Thread
fuel injector cleaner???????? CMARJEEP ZJ Grand Cherokee Forum 11 08-04-2011 10:50 AM
4.0 possible fuel injector problem or fuel sending unit metroman ZJ Grand Cherokee Forum 2 08-15-2009 02:37 PM
fuel injector replacement slammed68bug ZJ Grand Cherokee Forum 4 08-01-2009 01:55 PM
Fuel Injector Type dino61 ZJ Grand Cherokee Forum 6 07-23-2008 04:24 PM
Fuel Injector Cleaners Jeep4Life ZJ Grand Cherokee Forum 5 03-03-2003 12:07 AM
