fuel gauge - JeepForum.com
post #1 of 8 Old 09-20-2003, 08:26 AM Thread Starter
KeNTeChNiCaL
fuel gauge
My fuel gauge i have noticed has stuck at the half-empty mark.
Is this a sign of a failing fuel pump ?
1995 JGCL 5.2V8, Dual 3" exuast w/2 flowmasters 50 SUV series no converter(No smog testing req'd in MI)
KeNTeChNiCaL is offline
post #2 of 8 Old 09-20-2003, 09:14 AM
Harald
No, it's sign of a defect fuel gauge. Lot of this on model you have. Mine seems to stop at 1/4.
Harald is offline
post #3 of 8 Old 09-20-2003, 11:36 AM Thread Starter
KeNTeChNiCaL
how do ya fix this.....is it in the tank or at the instrument cluster ?
1995 JGC 5.2L full time 4x4
post #4 of 8 Old 09-20-2003, 12:39 PM
pozner
The diagnostic procedure is basically universal. If you ground the fuel gauge wire, and the gauge shows Full, then the gauge is good (and the sender is the culprit).
The wire needs to be removed from the sending unit before doing this. Attach the connector to a good grounding point and turn the key to the 'run' position. The needle will sweep from its rest position to the opposite side.
Poz
'94 red Grand Cherokee
Six cyl.
pozner is offline
post #5 of 8 Old 09-20-2003, 12:44 PM Thread Starter
KeNTeChNiCaL
by chance do you know where this unit is ?
post #6 of 8 Old 09-21-2003, 01:40 AM
pozner
The sending unit for the fuel gauge is part of the fuel pump assembly. Near as I can tell, the wire is black/orange. Not sure if the connector can easily be accessed with the tank in place. Any one that has replaced their own fuel pump can give you first hand info, or look for a fuel pump replacement thread.
Poz
Six cyl.
pozner is offline
post #7 of 8 Old 09-21-2003, 02:35 PM
Harald
To replace fuel pump, tank down on the ground. Done it on a Cherokee, took the better part of a weekend. If rust, have new strapping arrangement ready. I had to chop off mine, impossible to unscrew. Some work, but not difficult. Beware that you are working with gas vapour.
Harald is offline
post #8 of 8 Old 09-22-2003, 10:13 PM
crash98
Yeah my fuel gauge will show proper fill leve then drop to empty then back to wherever it was then empty and so on every once and a while.
97 Grand Cherokee 4.0
4 tv's+dvd+vcr+sega dreamcast
2- 15 visonik subwoofers
and about 4600 watts of power
http://members.cardomain.com/crash98
crash98 is offline
New guy saying hi and a fuel gauge? falcon10 WK Grand Cherokee & XK Commander Forum 15 11-02-2015 09:19 PM
Fuel Gauge Needle is dead... Low Fuel Light always on... any ideas? 95_JGC ZJ Grand Cherokee Forum 20 03-30-2015 09:30 PM
P0123 Code & No Fuel indication on Fuel Gauge & No start HookedOnReefing ZJ Grand Cherokee Forum 7 06-27-2009 10:26 PM
Fuel gauge off rwild ZJ Grand Cherokee Forum 3 02-19-2006 10:34 AM
fuel gauge centraltx ZJ Grand Cherokee Forum 1 03-25-2002 01:15 AM
