fuel & firing at same time ! - JeepForum.com
post #1 of 5 Old 08-17-2009, 04:35 PM Thread Starter
skiebuster
Tsconver told me to take my Jeep to the dealer to get my 99 WJ GC on the drb scan tool to reset my puter so that my timing issue for the injectors will be spot on.
I took it there friday, talked with the techie and he knows what to do.
After not getting it to even run friday he worked with it some today and still not running.
Its only barking out the exhaust and the intake.
He cant set the puter since it wont even run now. 1 set of plugs have fouled out and its still getting fuel and ignition at the same time.
Could I have damaged the crank sensor nd move it just a touch while installing the newer motor and that is causing it to run erratic ?
skiebuster is offline
post #2 of 5 Old 08-17-2009, 06:05 PM
rm2001wj
rm2001wj's Avatar
It might be better if you supplied a few more details, especially about the newer motor.
rm2001wj is offline
post #3 of 5 Old 08-17-2009, 08:29 PM Thread Starter
skiebuster
06 wrangler motor, I used everything from my 99 GC, all electrical components and flexplate n dorkconverter. Even the cam sensor as the 06 is a different type plug in.
post #4 of 5 Old 08-17-2009, 08:54 PM
rm2001wj
rm2001wj's Avatar
Which crankshaft position sensor are you using?
rm2001wj is offline
post #5 of 5 Old 08-17-2009, 09:00 PM Thread Starter
skiebuster
The factory 99 sensor. if i had used the flexplate from the 06 wrangler i wood have to use a 06 sensor, which is a longer sensor as the flexplates are smaller on the wranglers.
thanks !
Fuel gauge reads E ALL THE TIME! jeepunlimited ZJ Grand Cherokee Forum 9 07-10-2015 04:55 AM
Time for a New Fuel Pump??? CorneliusRox ZJ Grand Cherokee Forum 0 06-18-2009 09:32 PM
Towed Caravan for first time and really happy with fuel consumption DarrylFlynn WK Grand Cherokee & XK Commander Forum 0 03-20-2009 07:36 AM
Fuel pump? I think the time has come... veddderman123 ZJ Grand Cherokee Forum 1 09-21-2008 12:33 PM
Fuel Pump Time? nbjly ZJ Grand Cherokee Forum 5 03-03-2006 09:51 PM
