fuel filter - JeepForum.com
post #1 of 6 Old 08-30-2002, 07:52 AM Thread Starter
luken18r
luken18r's Avatar
fuel filter
where exactly is the fuel filter located on the ZJ (4.0)? I was under there last night and couldnt spot it
-Luke
ZJ - RIP
JKU - Awesome
luken18r is offline
post #2 of 6 Old 08-30-2002, 02:52 PM
Bigjake
What year? I have a 97' and think it is located in the gas tank as one unit(feul pump, fuel filter, fuel gauge). Is this true and how would you replace the fuel filter in the gas tank? After how many miles should you replace it?
BigJake
Bigjake is offline
post #3 of 6 Old 09-01-2002, 11:21 AM
Texas96
I just changed mine this morning. I have a 5.2 so I don't know how different they are. My fuel filter was located just above the rear axle on the drivers side. On the 5.2's, the filters on the 97's and up are located in the tank. The Jeep manual says the internal filter does not need to be changed. I assume only in extreme cases (such as fuel contamination) would you ever need to change it. J
Texas96 is offline
post #4 of 6 Old 09-01-2002, 12:41 PM
monch66
What about a 94? Where is it located?
94 JGC
monch66 is offline
post #5 of 6 Old 09-03-2002, 09:00 AM Thread Starter
luken18r
luken18r's Avatar
w3rd...thats what i like to hear
-Luke
ZJ - RIP
JKU - Awesome
luken18r is offline
post #6 of 6 Old 09-07-2002, 11:24 AM
Big Dumb White Guy
Big Dumb White Guy's Avatar
right under the passengers seat. obviously on the outside. crawl under the rearand take a look. it's bolted to the underside of the body.
1.) open your gas cap.
2.) open hood and go to the big fuse box on pass. side. take out the fuel pump fuse.
3.) crank over the engine. it may start and then crap out or not ever start. just keep cranking for 5 seconds or so.
that should bleed any pressure that your fuel lines may have. don't forget to put that fuse back in before you start it back up, when you're done.
another thing to do is to do it in the morning before driving. that lets out alot of the pressure.
when you buy the filter, either buy the tool to get the clips out or buy 2 more clips. and a lot of fuel comes out when you unhook the quick-disonnects. not like gallons but more than you want all over you. so stay to the side when you do it.
good luck!!!!
repost Nazi's suck!
A guy walks into the psychiatrist office wearing only Glad Wrap shorts. The shrink says, "Well, I can clearly see you're nuts."
Big Dumb White Guy is offline
CRD Fuel Filter BigSensFan WK Grand Cherokee & XK Commander Forum 28 02-04-2015 08:38 AM
99 wj fuel filter Howiedooit ZJ Grand Cherokee Forum 5 01-17-2010 04:41 PM
07 fuel filter? JETBLACKGC WK Grand Cherokee & XK Commander Forum 5 05-15-2008 10:42 AM
Fuel filter help for a 94 ZJ deeznutz206 ZJ Grand Cherokee Forum 4 11-22-2007 03:36 PM
Where is the fuel filter on an 01 GC V6? jb22304 ZJ Grand Cherokee Forum 1 08-01-2004 11:31 PM
