Ft Seat/Broken Bolt/ Broke Easy Out/ Cobalt Drill Bit ?? - JeepForum.com
post #1 of 16 Old 06-02-2012, 09:39 PM Thread Starter
hdrocknroll
When I got the ZJ the front left seat mounting bolt on the drivers seat was broke off.
I had to replace the seat because it was trashed, I got the other bolts out.
I drilled a hole and ,used an easy-out, that was actually too small for the job. So I broke it off.
The seat wiggles around the little, with only three bolts, so I need to fix it.
I tried drilling after I broke the easy-out, but . The easy-out is hardened steel so a regular drill bit won't cut it.
My question is, do you think a cobalt drill bit will work to drill out the easy-out ?
OR should I drill a different hole and tap it out ?
OR Any Other Ideas ?
Always !! Keep A Firm Grip On Your Tool !!
Watch Out For The Air Hose Gone Wild!! Or Wear A Cup,: True Story
Originally Posted by rooster51 View Post
Whats the worse that can happen? Your jeeps already broke.
hdrocknroll is offline
post #2 of 16 Old 06-02-2012, 10:04 PM
JasonStebbins
I'm confused. By easy out you mean the sockets with the spirals inside to remove rounded-off bolts? How did you "break" it? And you want to drill out the entire thing now including the bolt?
I would just drill and tap a new hole near that one.
JasonStebbins is offline
post #3 of 16 Old 06-02-2012, 10:14 PM Thread Starter
hdrocknroll
You know, the head has snapped off a bolt,so you drill a hole in the center of the bolt then insert an easy-out/ screw extractor, which kind of looks like a drill bit, with spirals on it !!
post #4 of 16 Old 06-03-2012, 09:20 AM
jaguarjoe
The seat belt system on your Jeep should be warranted forever. It's that way on a lot of other vehicles too. Call the stealership and start there. Let them do the dirty work.
The emissions system is warranted for 50,000 miles. That includes sensors tied to the PCM, the PCM itself, cat converter, and probably much more that I can't think of. That's why heated O2 sensors were invented. Generally HO2's don't die before 50,000, a lot of unheated units did/do.
Once I thought that drinking beer was bad so I just stopped thinking
jaguarjoe is offline
post #5 of 16 Old 06-03-2012, 10:07 AM
Dyn0mitemat
If you want that bolt out you'll either have to get a carbide drill bit or grind it out
09 Rubi 2dr:MetalCloak2.5", 37"MTZ's/Slabs, EVO Stff, ORFab Cage, Chromo's, Driveshafts etc
Dyn0mitemat is offline
post #6 of 16 Old 06-03-2012, 11:59 AM
Foundrydude
Switch your thinking. I beleive the bottom of that bolt is a square metal tab spot welded to the floor.
Attack the spot welds with a grinder/dremel or chisel to weaken them, then hit from the topside to knock it loose.
I have also had success with just giving them the mother of all hammer hits from the topside, no grinder or chisel, the spot welds fail without much damage to the floor. If the floor moves, just move it back
You'll have to use a normal nut.
good luck
Foundrydude is offline
post #7 of 16 Old 06-03-2012, 03:38 PM
gearheadnick
Once an easy out is broken, it's nearly impossible to get the broken part out. I stopped using them since I've broken every single one I've ever used. I would take Foundrydude's suggestion, and remove the bolt tab from the floor with a spot weld cutter or an appropriate sized drill bit. Assuming you have access to a welder, remove the old nut, weld in a new one, and reweld the tab back to the floor.
My cylinder head overhaul:
My transmission overhaul: http://www.jeepforum.com/forum/f13/how-change-transmission-electronics-1560948/
gearheadnick is offline
post #8 of 16 Old 06-03-2012, 05:41 PM
Foundrydude
The tabs are welded to the floor for ease of assembly, there is no need to weld a nut back in place or anything like that. Just use a regular nut, it's a little more clumsy to assemble but that's it.
post #9 of 16 Old 06-03-2012, 08:39 PM Thread Starter
hdrocknroll
Problem is ,As far as I know ,there is no access to the back side of this particular location,
(driver seat Lt Ft mount/bolt) unless there is an access hole under the carpet.
Side View
Front View
post #10 of 16 Old 06-03-2012, 09:11 PM Thread Starter
hdrocknroll
Now I'm thinking, drill an access hole on the back side of the little hump,
twist the weld nut off, put on bolt, washers and nut.
post #11 of 16 Old 06-03-2012, 10:36 PM
timmay5309
:: Subscribed :: My passenger seat has the exact same problem with a broken bolt and I have delt with it for the past 8 years... Curious what others have done to remedy it...
timmay5309 is offline
post #12 of 16 Old 06-04-2012, 01:01 PM Thread Starter
hdrocknroll
How about it.
Are there any access holes in the little hump???
Some one must have had there carpet out
post #13 of 16 Old 06-04-2012, 02:45 PM
gabrod72
If you got some easy outs that were made in Asia, then just find a suitable American made bit. Sears has some nice ones or you could get some titanium tipped ones. The key is to drill slow and while applying constant speed and pressure. Also, you can have someone spray small amounts of WD40 while you drill.
If you got some American made easy outs, then you'll probably need the cobalt bits... but not Asian ones. Just like steel, not all cobalt is created equal.
_______________________________________________
WARNING: Lo barato sale caro (Cheap things often lead to more expense)
gabrod72 is offline
post #14 of 16 Old 06-04-2012, 04:51 PM
98mopar
I have had great luck with bolt extractors. The good ones, like posted above.
I think the key is to be fast with them. When you drill the hole, it heats it up pretty hot. Then I put the extractor in and hammer it down. Then I pull it out. I have had good luck that way.
--- 1998 ZJ 5.9 Limited - 4" lift, 31 x 10.50 15, Jet chip, Kenwood Excelon everything, current DD
--- 1996 ZJ Laredo - Parts parts and more parts
--- 1993 ZJ Laredo - 4.0 Bone stock for now (New to me)
98mopar is offline
post #15 of 16 Old 06-04-2012, 05:14 PM
Foundrydude
You answered your own question!
memory says there are some holes in that reinforcing rib but I'm not sure if they're anywhere that will help ya. No big deal to drill an access hole though.
It's kind of suprising that bolt broke. Usually they only break when the threads are rusty from being exposed to the road or they bind up from being slathered in undercoating.
Wonder if it was cross threaded from the factory.........
good luck
seat bolt , seat bracket
Easy question 95 GC,1 bolt or 2 bolt CPS? Curtiss-Jeep ZJ Grand Cherokee Forum 2 05-17-2010 01:02 AM
E brake cable broke easy fix?? CrazyDrivinJoe ZJ Grand Cherokee Forum 5 02-29-2008 11:22 AM
Easy way to get Track bar TRE bolt off? ZJcrawler45 ZJ Grand Cherokee Forum 11 07-14-2007 05:44 PM
Heated seat not working? Easy fix? Heracles ZJ Grand Cherokee Forum 3 02-13-2007 08:38 PM
broke bolt do i need it? bryans 86 ZJ Grand Cherokee Forum 3 05-06-2006 01:56 PM
