Front wheel bearing/hub replace question - JeepForum.com
post #1 of 8 Old 05-12-2010, 05:38 PM Thread Starter
EBT531
Seems pretty straight forward, but 1 question:
Will any diff lube come out when I remove the old bearing/hub? Or is there an inner seal that will prevent this from happening?
Basically just checking if I should pull the diff lube before the bearing in order to prevent a mess.
Thanks
EBT531 is offline
post #2 of 8 Old 05-12-2010, 05:57 PM
Virmagicus
Virmagicus's Avatar
Your good. Pull the bearing/hub. No surprises.
Jeff
Virmagicus is offline
post #3 of 8 Old 05-12-2010, 06:23 PM
li'l jeep
Always a Pirate
li'l jeep's Avatar
Yuppers, nothing will come out. Just make sure those hubs are tight!!!! It calls for 170 ft lbs. I would suggest to get no less than 160! I did the old school way of snugging down but I lost more hubs than I care to remember that way. TIGHT TIGHT TIGHT!!!!
Best way is a long bar on the axle nut and have someone hold the hub with a screwdriver on the studs (protected by a lug nut of course). Really crank down because front hubs are expensive and a bad one leads to eraser style tire wear!
1997 ZJ Ltd. 5.2L V8
2003 WJ Ltd. 4.7L V8
GOD BLESS AMERICA!
li'l jeep is offline
post #4 of 8 Old 05-12-2010, 06:40 PM
bigb229
put some outter seals on that axle tube while youre at it....keep the grime out.
bigb229 is offline
post #5 of 8 Old 05-12-2010, 10:19 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
Get a real torque wrench. You should be using it on your lug nuts and other repair work anyways.
The spec is 175, even 10ftlbs +/- will lead to premature failure.
ratmonkey is offline
post #6 of 8 Old 05-12-2010, 10:43 PM
WiCkeDuDe
WiCkeDuDe's Avatar
At the dealership I worked at torque wrech = impact gun. Yes this even included head gaskets.
I Have WJ Stuff for Sale
WiCkeDuDe is offline
post #7 of 8 Old 05-12-2010, 11:09 PM Thread Starter
EBT531
Gotcha covered. I torque everything.
Thanks everyone. I was pretty sure, but didnt want that "oh crap" moment as fluid poured out
EBT531 is offline
post #8 of 8 Old 05-13-2010, 06:36 AM
KJK
Please post dealer name so we can avoid them.
5.9 ZJ SCT tuned PCM/ KJK CAI/ Thorley headers with 3" Magnaflow cat and muffler/ Modded kegger/ TransGo shift kit/ Vanco brake kit/ Braided steel brake lines/ Mopar cupholder insert!
KJK is offline
How to replace an axle shaft and/or a wheel hub bearing assembly w/PICS! ArloGuthroJeep WJ Grand Cherokee Forum 339 03-26-2016 07:53 AM
Need help! ZJ front wheel bearing! dubaudi ZJ Grand Cherokee Forum 11 03-13-2010 08:55 PM
How to replace wheel bearing Mustang ZJ Grand Cherokee Forum 3 03-20-2009 10:56 PM
Front axle bearing replace wahoo50 ZJ Grand Cherokee Forum 1 03-19-2007 07:41 PM
Front Wheel Hub/Bearing Help ojingalena ZJ Grand Cherokee Forum 2 02-04-2005 09:15 AM
