Front tow hook, where? - JeepForum.com
post #1 of 9 Old 07-06-2013, 02:50 AM Thread Starter
Adam86
From being on this forum it would appear that the stock tow hook is not strong enough.
What do l need and where should l fit a stronger tow hook on the stock front end with bumper removed?
Cheers
Adam86 is offline
post #2 of 9 Old 07-06-2013, 05:56 AM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
Strong enough for what?
04 4.7 HO, limited
04 4.7 HO, Overland
08 Z71 Suburban, front leveling kit with rear spacers. 285/65 18s Nitto TerraGrappler G2s
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
For your performance needs:
480.998.366
Texas ZJ1 is offline
post #3 of 9 Old 07-06-2013, 06:47 AM
BrandonsZJ
Look into buying a KOR radiator support. http://www.kevinsoffroad.com/cart/ra...rcoated-p-285/
BrandonsZJ is offline
post #4 of 9 Old 07-06-2013, 08:57 AM
kachink
Not sure where you got that idea. What I've seen on the forum is that stock hooks with the stock brackets and backplates are ok. The KOR radiator support is better though, or hooks/shackles on a well built, well attached bumper.
kachink is offline
post #5 of 9 Old 07-06-2013, 09:03 AM
tucsonzj
I've been towed up a steep rocky incline from 1 of my front two hooks before. Worked good for me.
His:00 TJ "Fiona" stuff/stuff/stuff
95 ZJ 3.5" w/242 swap-Sold
Hers: 15 JK Sahara-3" Teraflex
tucsonzj is offline
post #6 of 9 Old 07-06-2013, 11:07 AM
a70eliminator
What everyone else said has been my experience as both a recovered and recovery vehicle, the factory front hooks couldn't be in a stronger location because there aint one, with the back plates and load distributing bracket the hooks are as good as it gets.
a70eliminator is offline
post #7 of 9 Old 07-06-2013, 11:22 AM
Mickey_D
The only real down side to the factory tow hooks is in side loading. The previous owner of my ZJ got it stuck at one point and looped the tow strap from the tow ball on the truck, through one hook on the ZJ, then through the other hook and back up to the tow ball on the truck. When they gave a good tug it bent both hooks inward about 10 degrees.
1997 ZJ 5.2 Orvis, Baby!
1953 Willys M100 trailer Tagalong
________________
[_][][][][][][][][_]
#4
Mickey_D is offline
post #8 of 9 Old 07-06-2013, 01:09 PM
tucsonzj
Mines bent from a rock lol
tucsonzj is offline
post #9 of 9 Old 07-06-2013, 03:15 PM
Syncityj
The tow hooks, when used with all corresponding parts from factory have been rated at 10k lbs. should be plenty if you ask me
Sent from Hell
Syncityj is offline
