front to rear swap. - JeepForum.com
post #1 of 7 Old 06-29-2014, 06:48 PM Thread Starter
brokenshoe14
front to rear swap.
Im wanting to do a front to rear swap. My issue im having is idk whst coils to get for the front. Its a 96 4.0 ive read some places bronco coils are a direct fit. But no word on what yr or if its bronco 2 or fullsize... any info would be greatly appreciated
brokenshoe14 is offline
post #2 of 7 Old 06-29-2014, 09:27 PM
kg6mov
Hears the voices
kg6mov's Avatar
Just get 3.5" lift coils for the ZJ?
There's a thread around here using f150 coils in the front for a 3.5" lift with the f > r. He basically rode with it for a while, got tired of it riding like *** and got a real lift. Do it right the first time and you'll save money.
kg6mov is offline
post #3 of 7 Old 06-29-2014, 09:47 PM Thread Starter
brokenshoe14
Its just for a temp boost in hight untill I can get my 6.5" long arm and 35s. I just got 31s not long ago(couldnt resist for the price. 450 for all 4 mounted and balanced) so I basically just want the little bit extra clearance till they are ready to be replaced. I still get a little rub with 2" spacer lift. But I also run no sway bars so a stiffer ride doesnt bother me
post #4 of 7 Old 06-29-2014, 09:49 PM
kg6mov
Hears the voices
kg6mov's Avatar
Trim? Run wheel spacers? I really wouldn't run more than 2.5" on stock CA's.
And put your swaybars back if you're driving on streets! Discos or gtfo.
kg6mov is offline
post #5 of 7 Old 06-29-2014, 09:53 PM Thread Starter
brokenshoe14
Im very against trimming lol I have 0 rust or rot on my zj so no trimming yet and working on wheel spacers. But I have connections at the local junkyard so I get anything I need dirt cheap. So the f> r seemed like a good option to hold me over for about a yr and allow me to save to finish the build in 1 shot
post #6 of 7 Old 06-29-2014, 10:05 PM
kg6mov
Hears the voices
kg6mov's Avatar
Have you done anything other than the spacer and different shocks? A f>r is going to need trackbars and really needs CA's, it's not "cheap" it's just "cheaper".
kg6mov is offline
post #7 of 7 Old 06-30-2014, 11:50 PM Thread Starter
brokenshoe14
Have ajustable track, havnt done ca yet.
