Are Front to Rear Differential Ratios the same ? - JeepForum.com
post #1 of 34 Old 09-12-2013, 03:47 PM Thread Starter
joe19934
Ok I found a Rear Differential for $125 only thing is I'm not sure about the ratio as there is no tag on it.
I pulled of and cleaned the front tag & it says 3.73 so should the rear differential be the same ?
Logically I would think it had to be the same ratio does anyone have any feedback or suggestion on this ?
Thank you in advance,
Joe
joe19934 is offline
post #2 of 34 Old 09-12-2013, 03:49 PM
jm8881
Yes. Unless it's a trail only rig but then they should be within .01. Like 4.11's in (i think) fords and 4.10 in jeeps/chevy.
jm8881 is offline
post #3 of 34 Old 09-12-2013, 04:00 PM
riot1987
F&R have to be the same ratio or it will bind in 4wd
Build thread^^
riot1987 is offline
post #4 of 34 Old 09-12-2013, 04:04 PM Thread Starter
joe19934
That's what I figured because it would mess up the AWD
If You can't Go Around It then Go Over It !!!!!!!!!
joe19934 is offline
post #5 of 34 Old 09-12-2013, 04:12 PM
riot1987
3.73's were very common in ZJ's there were also made with 3.55's so you have to watch for those
Build thread^^
riot1987 is offline
post #6 of 34 Old 09-12-2013, 04:32 PM Thread Starter
joe19934
OK got it but the front tag says 3.73 I hope someone didn't change it...
joe19934 is offline
post #7 of 34 Old 09-12-2013, 04:57 PM
newfieZJ
Since this is a new to you diff , your gonna want to change the oil . When you pull the cover , on the side of the ring gear will be stamped 41/11 , just rotate till seen . That's a 3.73
1995 Orvis build
1988 MJ build
1998 Slate 5.9 build
1998 Platinum 5.9 build
newfieZJ is offline
post #8 of 34 Old 09-13-2013, 03:21 PM
jeeepguy
jeeepguy's Avatar
You can determine the ratio of any setup by finding the numbers on the ring gear that newfieZJ mentioned and dividing the first number by the second number.
"Si Vis Pacem Para Bellum"
"Great danger lies in the notion that we can reason with evil"
Doug Patton
...We use words like honor, code, loyalty. We use these words as the backbone of a life spent defending something. ...I have neither the time nor the inclination to explain myself to a man who rises and sleeps under the blanket of the very freedom that I provide, then questions the manner in which I provide it. I would rather you just said thank you, and went on your way, Otherwise, I suggest you pick up a weapon, and stand a post...
I bought the HI-WAY BLASTER HORN that's 139dB and every time I honk the horn an Angel dies.
Revelation 13:16-18
16 - He causes all, both small and great, rich and poor, free and slave, to receive a mark on their right hand or on their foreheads,
17 - and that no one may buy or sell except one who has the mark or the name of the beast, or the number of his name.
18 - Here is wisdom. Let him who has understanding calculate the number of the beast, for it is the number of a man: (Real ID and RFID chips)
Think about it...
jeeepguy is offline
post #9 of 34 Old 09-13-2013, 09:32 PM Thread Starter
joe19934
Ok it took me most of the day but I got home today with a 3.73 Rear for only $125 after looking it over at the parts salvage yard...
I see it as a day spent driving around with the Wife lol
Anyway when I got home I crawled under the Jeep and spotted 1 difference which is I have a vent on the left side and the brake splitter block is on the left side of the rear.
The one I just picked up looks to only have the vent that is routed through the brake splitter block which I hope wont make any difference I hope ??????
Could the one I just picked up be out of a older model mine is a 98 !
joe19934 is offline
post #10 of 34 Old 09-14-2013, 12:09 AM
5-90
5-90's Avatar
1988 XJ Cherokee
Joe
Yes, within a couple of points. If they're not close, the tcase will end up binding because it can't spin the shafts differently.
If it's a different ratio, you can remove the associated driveshaft until you can get the axle regeared with no ill effect.
"recon" (sic - reckon)(tm) "hihgly"(tm) "seceed"(tm)
"Outback AIDS - Alcohol-Induced Dizzy Spells"
5-90 is offline
post #11 of 34 Old 09-14-2013, 03:38 AM Thread Starter
joe19934
The one I just picked up has the same 3.73 ratio as the front one IRS just the single vent tube I was worried about on the replacement rear.
joe19934 is offline
post #12 of 34 Old 09-14-2013, 04:25 AM
newfieZJ
Me thinks you bought a D35 , not a 44a . Bolts up and will work , but , your driveshaft is going to be 1 " short at least now
newfieZJ is offline
post #13 of 34 Old 09-14-2013, 07:21 AM Thread Starter
joe19934
OK if it is beside bringing back what could be done?
joe19934 is offline
post #14 of 34 Old 09-14-2013, 07:29 AM
newfieZJ
If you want no hassle with the drive shaft , return it , get a 44a . Diff has an aluminum case on the 44a , bring a magnet .
newfieZJ is offline
post #15 of 34 Old 09-14-2013, 08:28 AM Thread Starter
joe19934
OK just checked it and a magnet sticks to it so I'm guessing you're right its a Dana35...
I just called the Owner of the Parts Yard and it was taken out of a 1998 Grand Cherokee with a 5.2L so I'm guessing the owner of the Jeep swapped it out and the person I bought it from has no Idea what he's selling ????????
Can my driveshaft be modified or will it work as is for now ?
What if the guy has the rear driveshaft that came out of that Jeep maybe that has been modified to work already ?
joe19934 is offline
