front to rear coil swap - JeepForum.com
post #1 of 3 Old 09-26-2011, 09:56 PM Thread Starter
feezin17
So I just bought a 98 zj (first jeep) buying bfg ta's pretty soon but before that I wanna do a front to rear coil swap cause after looking at it, it seems like it could be possible and potentially a lot cheaper than a lift kit even though i probably will have to buy shocks and coils but oh well thats what scrap yards are for.
So if anyone knows how to do this and what parts are needed please let me know. Thanks for help!
BTW I have the 5.2 v8 (Limited)
Also would i have to drop the transfer case?
feezin17 is offline
post #2 of 3 Old 09-26-2011, 10:26 PM
sskilla
little search will turn up everything you could need and more.
but, since im here.
F > R swap: 1) 3.5" front lift springs
2) Extended sway bar end links (can get away with stock for a bit but they are going to be stressed.)
3) adjustable rear track bar (or track bar drop bracket if you dont have the funds just yet)
4) adjustable front track bar recommended
5) new shocks for your new ride height
thats really all that is required. however know that your ride quality is going to suffer without new control arms or bushings.
you shouldnt need a t-case drop unless you get vibrations. most of us dont however.
'95 ZJ: 5.2 v8 / 231 Tcase / 46RH
sskilla is offline
post #3 of 3 Old 09-26-2011, 10:26 PM
PolkaPower
Shocks, sway bar end links, tracks bars front and rear, brake line extensions, coils, adjustable control arms, bump stop extensions, ect.
PolkaPower is online now
lift , lift advice , swap
ZJ Coil front to rear swap Sykora171 ZJ Grand Cherokee Forum 2 02-18-2011 07:01 AM
front to rear coil swap jeeper-chris14 ZJ Grand Cherokee Forum 10 11-19-2010 03:37 PM
are 3/4" coil spacer the same for front and rear? hike4it ZJ Grand Cherokee Forum 3 03-14-2009 10:05 PM
Front Coil lift in Rear? 87GrandWagoneer ZJ Grand Cherokee Forum 10 12-01-2007 12:47 PM
Front to Rear Coil Swap UTChavok ZJ Grand Cherokee Forum 2 10-25-2007 06:46 PM
