Front/Rear Brake Rotor Removal - JeepForum.com
post #1 of 10 Old 08-15-2005, 08:00 PM Thread Starter
AngryDog
I started to change the front and rear rotors on my 99WJ and immediately ran into a problem. I found it impossible to break free the anchor bolts on the backside of the anchor/caliper assembly. I broke my ratchet and a socket reducer. My electric impact wrench also could not break them loose. Is there a trick to breaking them free? I don't want to twist them off. Any help thanked in advance.
In His Service...
God says, “Choose for yourselves today whom you will serve”
As for me and my house, we choose the Lord. Joshua 24:15
AngryDog is offline
post #2 of 10 Old 08-15-2005, 08:15 PM
Phil Gerard
Former Mod
Phil Gerard's Avatar
I just soaked them in WD 40 and let them sit for a while but it sound to me like someone air gunned them tight which they shouldn't be.
No trick to it at all just get some PB or WD and soak em!!!
Phil
'95 ZJ Ltd. White 4.0L
TW DC DS; ARB Bull Bar, F&R Air Lockers; Superior Axles; Warn Winch; 4.56 gears; ACOS, Addco F&R Sw Bar, JKS Discos, Rr Track Bar & Nerfs, 249>242 Swap, Stillen rotors+Kolak pads, 3 pc. Armor, RE 4.5 Kit + 2.5"BB, Adj. UCAs&LCAs, OME SS, Bilstein 5150s, 15x8 AR Diamond Backs, 33 Truxus MTs, K&N FIPK, RE 62mm TB, Perf. Distr. 4.0L Kit, Exhaust: 2.5" Kolak exhaust FM 70: Optima Yellow, Mean Grn Alt., PIAA 520s, 540s, Kevins Rack, & TB Conversion
Phil Gerard is offline
post #3 of 10 Old 08-15-2005, 09:42 PM
oilcounter
Are you sure you were turning the correct direction? Since the bolt you are working on is one the backside of where you are standing. Think that by turning the ratchet clockwise you'll actually be spinning the bolt OUT of the hole..
2000 JEEP GRAND CHEROKEE I-6 (WJ)
All stock except for Mopar 3 disc In-dash CD player
Michelin M/S LTX 255/70/16
Metallic Taupe Jeep Club Member #15
oilcounter is offline
post #4 of 10 Old 08-15-2005, 10:43 PM
Brian's 97 ZJ
Brian's 97 ZJ's Avatar
I agree, make sure you are turning the bolts the right direction.
I just replaced the front rotors and front / rear breaks on my '97 and had no trouble removing them with a 3/8" drive ratchet.
You may run into trouble removing the rotors; they may be rusted to the hub. Tap on it with a hammer to help break the rust loose, they will eventually come off.
Sometimes your bleeders will refuse to open as well. Fear not! You can just take the cap off of the brake fluid reservoir and close the caliper shut with a c-clamp. You will force the fluid back up the line and won't have to bleed that wheel. You may need to remove some fluid as you are doing this so it doesn't overflow. Note: Brake fluid will ruin your paint if it sets on it too long.
My calipers were in near perfect condition. The sliders were intact and moved freely. I could push the pistons back in by hand. Disc brakes are wonderful.
HTH
- Brian
For some reason, being a member of the
just isn't as cool... Member #1
Brian's 97 ZJ is offline
post #5 of 10 Old 08-16-2005, 07:04 PM
parana6
I removed mine with a big brake bar
parana6 is offline
post #6 of 10 Old 08-16-2005, 09:42 PM Thread Starter
AngryDog
Job Completed
Thanks for all the help everyone. I had to have a seal replaced in the transfer case (under warranty) so I had the tech break the anchor bolts loose. They didn't charge me anything.
In His Service...
AngryDog is offline
post #7 of 10 Old 10-28-2009, 11:59 PM
chero6
I space is not an issue, use a cheater bar to break the torque. Then proceed on with ur 3/8 ratchet. No sense Hurking it you're gonna loose.
chero6 is offline
post #8 of 10 Old 10-29-2009, 09:15 AM
Brian's 97 ZJ
ZOMBIE!!!!
post #9 of 10 Old 10-29-2009, 09:33 AM
ArloGuthroJeep
Mr. Hyde!
ArloGuthroJeep's Avatar
Thanks for responding to a 4 year old thread
At first I thought Phil was back...
'14 WK2 Limited w/5.7L, ORAI, & Tow Package
ArloGuthroJeep is offline
post #10 of 10 Old 10-29-2009, 09:39 AM
CanadianZed-J
^ He gave the OP some time to let the WD-40 soak in.
CZJ.
So I installed the flux capacitor but the Jeep just won't do 88 mph.
-'99 WJ Limited, 4.7, Patriot Blue, 2" BB, 31" Mall-Terrains, Pavement Princess
-'97 TJ, Stone White, 4" Superlift, 33" SSRs, lunchboxed rear, 12K Titan winch, and 2.5 litres of exhillirating performance.
CanadianZed-J is offline
Rear Rotor Removal help CarFanatic ZJ Grand Cherokee Forum 25 05-07-2013 06:17 PM
Urgent help please re removal of front brake rotor/disc. DarrylFlynn WK Grand Cherokee & XK Commander Forum 9 12-02-2009 01:12 PM
Rear rotor removal on a 99 Grand Cherokee dirtyjeepdc ZJ Grand Cherokee Forum 5 05-08-2009 01:08 PM
Rear rotor removal mmgrand ZJ Grand Cherokee Forum 8 10-24-2006 05:41 PM
Rear Rotor Removal / Emergency Brake problems wvresq ZJ Grand Cherokee Forum 4 09-10-2005 11:32 PM
