Front passenger side power window not working - JeepForum.com
post #1 of 17 Old 08-22-2013, 01:24 PM Thread Starter
KiloWatts
I've searched a bit on the forums, and it seems like there's a specific order in which the power windows work. All of my windows work except for the front passenger side. I do hear a "click" when I hit the button, but no movement. Is that enough info to isolate the problem?
KiloWatts is offline
post #2 of 17 Old 08-22-2013, 02:46 PM
erisbrow
1994 ZJ
You are trying to control it from the passenger door or the driver door?
erisbrow is offline
post #3 of 17 Old 08-22-2013, 02:52 PM
erisbrow
1994 ZJ
At random times my passenger window wont be controlled from the driver door initially. If I lean over and hit the switch from the passenger door it will work and from then on I can control it from the driver door. I have no idea why, but thats been my experience.
Another problem I had was with the wire harness that comes from driver door into the jeep. Some of my windows were working intermitantly and sometimes depending on how far open or closed my driver door was. I peeled the boot back that covers the harness between the door and the frame and found a bunch of cracked and naked wires and even one completely broken.
Check those
erisbrow is offline
post #4 of 17 Old 08-22-2013, 03:23 PM Thread Starter
KiloWatts
Nope, it won't move from either switch. I can hear it clicking inside the door panel when I hit the switch, but no movement. I took off the panel and checked the harness and the boot, and they all look fine.
There is, however, a 3rd harness that's not connected to anything. One harness is the big one (12 wires or something), a second one connects to the power mirrors, and then there's a 3rd one that I can't find where it's supposed to go. It's a 2-wire harness, it comes from somewhere around the exterior handle location, and runs toward the frame, but just stops and is hanging there, taped to the other wires.
post #5 of 17 Old 08-22-2013, 03:30 PM Thread Starter
KiloWatts
LOL, I was looking through the service manual to see if I could find what that 3rd connector is for... Unfortunately, all I found was a picture of the darn thing, taped exactly how it is in my door:
I'm pretty sure that has nothing to do with my problem though.
post #6 of 17 Old 08-22-2013, 04:01 PM
coralman
USER OF PARTS CATALOGS
coralman's Avatar
That is probaly the harness for puddle lights on limiteds.
Originally Posted by HighLonesome
coralman is offline
post #7 of 17 Old 08-22-2013, 04:02 PM
coralman
coralman's Avatar
Fill out your jeeps profile information.
coralman is offline
post #8 of 17 Old 08-22-2013, 04:07 PM Thread Starter
KiloWatts
Done. I don't have a lot of info yet - I only acquired this fella four days ago.
post #9 of 17 Old 08-22-2013, 05:16 PM
JeepNicholson
Go here and request a build sheet for your Jeep from Chrysler
It likely won't be 100% accurate because Chrysler recycles their build codes (or so I've heard) but it's a great starting point!
http://www.chrysler.com/wccsapp/universal/C/index.jsp
They'll email you back pretty quickly
ZJ FSM
https://drive.google.com/folderview?...Fk&usp=sharing
JeepNicholson is offline
post #10 of 17 Old 08-22-2013, 05:17 PM Thread Starter
KiloWatts
Thanks... that first link didn't work though...
post #11 of 17 Old 08-22-2013, 05:21 PM
coralman
coralman's Avatar
These should help some.
coralman is offline
post #12 of 17 Old 08-22-2013, 05:25 PM
JeepNicholson
Oops. Here, try this, and choose "i need customer assistance" and then on the next page "send an email"
http://www.chrysler.com/webselfservi...sler/index.jsp
ZJ FSM
post #13 of 17 Old 08-22-2013, 05:28 PM
coralman
coralman's Avatar
You can verify your voltages, and if you hear the click from either switch I would think you are getting power. You can disconnect the motor connector, operate your switches while backprobing the connector on the harness side and see if you have 12v. If so the motor may just be jamned either internally or the regulator may be jammed up somehow. Pull the door panel off snd poke around abit. Take your time when releasing jeep connectors because the lock tabs break easily. Will help where I can.
coralman is offline
post #14 of 17 Old 08-22-2013, 05:44 PM Thread Starter
KiloWatts
Thanks for the help. I googled backprobing. I have a multimeter. Lemme see if I have this right. In order to check voltages, I'll insert the negative needle into the ground (black) wire port, and the positive needle into the other wires - correct?
post #15 of 17 Old 08-23-2013, 03:10 AM
coralman
coralman's Avatar
Correct, the little pins used sewing work good.
coralman is offline
