front noise after removing front skid plate - JeepForum.com
post #1 of 3 Old 12-06-2008, 08:09 AM Thread Starter
davets
1956 CJ5
2002 WJ. I removed the front skid plate to fix a tranny line. I didn't put it back on yet. Now when entering a driveway or going over dip in the road there is a scraping noise up front. It sounds like if the sway bar end links are making contact with the inner fender liner and scraping as the suspension cycles up. Not a metal to metal sound. I see no points of contact. I sprayed up the end link bushings, frame mount sway bar bushings and control arm bushings with silicone and it still is there. I'll disconnect the shocks first then the sway bar end links to see if that does it but any ideas? Thanks.
*** 1956 CJ-5, milled head,elec fan,power steering,4-whl discs,rubber mounted cage,all drivetrain and engine incl distributor vented into firewall,Saturn overdrive,Lockrites,Rezeppa joints,2 1/2" springs arched add'l 1 1/2", homemade expanding shackles,reinforced frame,glass tub, stainless tank, 31X15.5 Terras on 15x10 and 15X12 rims-trail, 31X10.5 A/T's on 15X10 alum rims-street,Amsoil.
davets is offline
post #2 of 3 Old 12-07-2008, 03:23 AM
311LJ
311Popo
311LJ's Avatar
well I'm not exactly sure. but with your skid plate does it use some bolts that hold part of the "frame" and stuff together? maybe without them in there are spots that are separating or grinding. put the plate back on and see if it fixes it, or look where the bolts go and see if they were holding anything together besides the skid plate to the "frame/unibody"
John
04 TJ Unlimited, GenRight Armor, 37's
89 XJ Laredo, 31's
07 WK Overland, Hemi, Chrome bug deflector
[SOLD] Jimmer 01 WJ *2009 GCOTY*
I ♡ John
311LJ is offline
post #3 of 3 Old 12-08-2008, 05:54 AM Thread Starter
davets
1956 CJ5
Thanks. Skid plate back on and still noisy. One shock leaking. Still haven't pulled them off to check.
davets is offline
4XGuard Front skid plate thequif WK Grand Cherokee & XK Commander Forum 9 09-17-2009 09:28 PM
howling noise front front of 01 WJ aquafresshness ZJ Grand Cherokee Forum 7 05-25-2009 10:50 AM
Front Skid Plate mrfWKJeep WK Grand Cherokee & XK Commander Forum 23 10-15-2007 07:20 PM
Front Skid plate Schwarttzy ZJ Grand Cherokee Forum 8 08-17-2007 10:28 AM
Front Mopar Skid Plate with a lift... Does it work? Is it worth it? Soft 8 ZJ Grand Cherokee Forum 42 10-14-2006 08:32 PM
